603,392 active members*
3,388 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Hass VF-5 post arc/line interpolation problem
    Jul 2007
    41
    The featurecam post we have for our VF-5 has a problem, when we try to smooth out the 3d machining and cut down on the size of the program by using the Acr/Line interpolation check box we get error codes trying to run the program. The code says somthing about a bad number. anyone else have this problem? Could it be somthing to do with arc quadrant call outs ( half circle, quarter circle,) any response would be greatly appreciated
    May 2008
    16
    We have been working with a variety of Haas mills using point to point as well as curve fitting style of programming. The Haas controls do very well with both styles of programming. I have not seen any issues with the Haas using Master Cam’s curve fitting algorithm. You may run into a problem if the curve fitting creates arc segments that are too small.
    You can verify this by loading your program into the Vega DATA-View utility. This utility checks arc/circle statements for small angle errors and large radius errors. A fully functional demo is available at www.vegacnc.com
    If you are trying to smooth out the motion of your programs, try the DATA-Optimize feature of DATA-View. This feature will embed acceleration/deceleration points into your program and allow the Haas control to run faster and smoother. Some of our customers have more than doubled their typical feedrates and the part finish is better. They are also reporting a significant reduction in tool wear due to smoother material engagement.
    Enjoy!
  1. Fanuc 16i-m Helical Interpolation Problem
    By Goran P. in forum Fanuc
    Last Post: 03-27-2009, 08:41 AM
  2. need a post with out circle interpolation 9.1
    By kojack in forum Post Processors for MC
    Last Post: 01-21-2008, 09:15 PM
  3. Circular interpolation problem
    By L. Sakthivel in forum Fanuc
    Last Post: 10-17-2007, 08:26 AM
  4. Mazak Mill Circular Interpolation problem
    By DublJ in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-13-2007, 06:13 PM
