587,791 active members*
3,009 visitors online*
Results 1 to 8 of 8
    Jul 2008
    45
    Haas TM-1 Ethernet
    I am having trouble sending programs to my machine from the computer. I can send them to the computer from the machine but not the other way around. I have 2- 25pin ports on my machine. There is a spot for an ethernet connection, but it is blocked off. Can I add an ethernet outlet to this machine or is this another "Haas has to do it" things?
    Thanks for any help.
    Robert
    15362
    Hi speed rider
    The ethernet comes with the hard drive package $2700-00 thats the only way to get it
    it is another board that gets put on the back of the CPU & Mocon Boards do you have the USB as you can load from there.
    Mactec54
    Jul 2008
    45
    It is a 2004 model. It does not have a usb port either.
    I am thinking my pinout is wrong. Does anyone know the pinout setup?
    I have the 25 pin on the Haas and a 9 pin serial on the computer.
    Apr 2005
    903
    This is a little confusing to me, what is the diffrence between the USB and Ethernet?
    Don't all new HASS machines come with the USB as of the beginning of this year?
    Jul 2008
    45
    Quote Originally Posted by l u k e View Post
    The ethernet is an RJ45 plug. It looks like a phone plug, just a little wider.
    Apr 2005
    903
    Quote Originally Posted by speedrider View Post
    That is the diffrence between the cables, what is the diffrence between the data transfer style? (Style is probably the wrong word, but you get the idea)
    Jul 2005
    340
    RS232 is a voltage transmission -18V <-> +18V, without any complex protocol, just dummy sending ASCII characters
    Ethernet is a current transmission , with a TCP protocol , very interference resistance.
    Mar 2005
    1498
    speedrider:
    Our I232 Isolator should allow you to run at 115.2 kbaud, over a long distance, and provide electrical isolation at both ends.
    For more information visit www.beta-a2.com .
  1. haas ethernet connections
    By Jim Walker in forum Haas Mills
    Last Post: 04-25-2010, 07:14 AM
  2. VF-1 + Ethernet
    By frogger in forum Haas Mills
    Last Post: 10-08-2007, 01:07 AM
  3. Haas Ethernet quesitons
    By 1ctoolfool in forum Computers / Desktops / Networking
    Last Post: 02-12-2007, 03:47 AM
  4. Haas ethernet setup?
    By the spyder in forum Haas Mills
    Last Post: 08-05-2006, 05:02 PM
  5. Haas Ethernet Circuit Board
    By cncguy1200 in forum Haas Mills
    Last Post: 08-23-2005, 09:00 PM
