Read about it here...
http://axis.unpythonic.net/01218391672
I'm pleased to announce the next release of the emc 2.2 series, emc 2.2.6. This version contains many bugfixes, a new unified driver for the Mesa PCI and parport cards such as 5i20 and 7i33, and a sample configuration for the Tormach PCNC 1100.
The new packages are now available in the package repository. If you have already installed an earlier 2.2.x version, this is available as an update. If you are still using 2.1.7 but want to upgrade, instructions are here.
CVS users can get this release by checking out the RELEASE_2_2_6 tag. Tarballs will be available on sourceforge.net within the next 24 hours.
fix hal_input manpage
Fix FTBFS on hardy (texlive-extra-utils)
(incompatible change) make debounce cfg= match the documentation If you use a debounce component with multiple groups (e.g., cfg="3 3") this must be changed to use commas instead of spaces: (e.g., cfg=3,3)
hal_ax5214h: driver fixes from Dave Brink
stepconf: fix spurious "application closed unexpectedly" messages (for this and other stepconf bugfixes, re-run stepconf and re-save your configuration file)
stepconf: fix "following error" messages when the requested step rate cannot be attained
stepconf: fix "following error" messages due to insufficient "stepgen headroom"
stepconf: if an exception is encountered, show it to the user in a message box.
stepconf: fix non-working configuration if "Onscreen prompt for tool change" was disabled
stepconf: allow entry of step and direction timings up to 500000ns
hal_ppmc: handle faster clock frequency for UPC 3.1 boards
hal_ppmc: correctly return IO regions at exit
software encoder counter: fix problem with negative velocity outputs
Fix handling of G61/G64 after Machine Off (SF#2006736)
new realtime component: gearchange. selects between two scale factors, two min and max speed limits, and optionally reverses direction of spindle
new realtime component: invert - outputs the inverse of a float (1/x)
new realtime component: ilowpass - scale and low-pass on integer values to smooth jog wheel action
added hostmot2 driver for 5i20 and 7i43
added sample configuration for the Tormach PCNC 1100
