587,104 active members*
4,270 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Lathe live tooling as spindle?
    Mar 2008
    201
    Hey guys,
    Has anyone tried using a lathe live tooling head as a spindle for a small mill? They tend to accept ER collets and are fairly small. The issues seem to be mounting a pulley and mounting it as a spindle.
    Say something like this:
    http://cgi.ebay.ca/VDI-40-LIVE-TOOLI...2em118Q2el1247
    or
    http://cgi.ebay.ca/VDI-30-LIVE-TOOLI...2em118Q2el1247
    Remove the gear and bore out a timing belt sprocket to fit. Maybe drill and tap some mounting holes. Would this work? What kind of speeds and loads are these rated for? Angular contact bearing or deep groove? (Not just these particular ones, but live tooling heads in general).
    Serge
    Aug 2006
    1602
    Wouldn't it be a lot easier and cheaper just to add a couple of bearings to a straight-shank ER collet-chuck?
    http://www.arceurotrade.co.uk/Catalo...-Collet-Chucks
    Mar 2004
    439
    You could just buy a Taig replacement spindle for $60.25. Look down towards the bottom of the page.
    http://www.taigtools.com/mlathe.html
    NEATman
    Mar 2008
    201
    The Taig has a pretty small bearing set (smaller than Sherline) and an aluminum case. I'd buy the Sherline steel cartridge spindle before that. The ER16 holder looks interesting, but the bearing ID would be 20mm, same as Sherline. So it wouldn't be much more rigid when all is said and done. Also I'd have to make an accurate case for it, which isn't the easiest thing to do with a Sherline lathe (concentricity and cylindricity to a few tenths). That would also mean buying a 4 jaw chuck, .0001 indicator, bearings, etc... without certain success.
    That ER25 live tool would have larger bearings and a cast iron/steel case. It's just adapting a pulley and mounting the thing.
    I'm surprised no one has tried this out yet. There aren't exactly a lot of quality choices for small mills that don't cost a fortune. You have the Sherline & Taig spindle, then there is a jump to a $1,300 Finley. It goes up from there. Not much in between. The Tormach spindle is interesting, but's it's just too darn big for the design.
  1. Cutting Hex On CNC Lathe With Live Tooling
    By 337MPH in forum MetalWork Discussion
    Last Post: 03-19-2008, 12:54 PM
  2. Lathe with live tooling
    By baldysm in forum Uncategorised CAM Discussion
    Last Post: 12-27-2007, 05:28 AM
  3. live tooling, c-axis.. lathe or mill
    By krazatchu in forum Uncategorised MetalWorking Machines
    Last Post: 05-10-2007, 02:51 PM
  4. Live tooling in Lathe package?
    By Linchpin in forum OneCNC
    Last Post: 04-19-2006, 10:13 AM
  5. Adding 3rd axis/live tooling to lathe
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 04-22-2005, 02:40 PM
