603,326 active members*
2,995 visitors online*
IndustryArena Forum > MetalWorking > Diemaking / Diecutting > Stamping Press For Sample Square Lids
    Jul 2008
    68
    I have a few questions and like to know is possible to do all this in one single stamp punch. The parts I like to do is very 4" x 4" x 1/4" lid and is 20ga 304 stainless steel. I like to have a very tight edge bends and 90 degree all sides.
    1. Is possible to do all these with single punch that include 4 corners notch out and fold back the 4 sides?
    2. What size or type of stamping press will work for this type of work? I looking for high speed run.
    Mar 2007
    158
    No, you cannot punch out the corners and do the bends in one press stroke. This will be done in a minimum of two strokes: First to punch out the corners, and second to do the bends.
    However, unless you need to do a whole lot of volume (maybe 5,000 pieces or more), you are better off doing the bends on a press brake one at a time instead of investing in an expensive die to wipe all four flanges at once.
    Regarding the tonnage needed, pretty much any press can handle this - you are not talking about any significant tonnage requirements. For punching the corners out, if you are starting with a blank that is already the exact size you need (minus the corner cutouts), you would only need around 5 tons to punch the corners out.
    Oct 2006
    976
    Mcyoda,
    Are you talking about a draw-form tool to form a 1/4" flange all around the cover without any corner notches?
    Regards,
    Regards,
    Wes
    Mar 2008
    240
    Look up "Pinch Trim Die". Used to combine drawing and trimming in one operation.
  1. swipe stamping?
    By Med-Pac in forum Diemaking / Diecutting
    Last Post: 01-25-2009, 08:34 PM
  2. Stamping?
    By dal in forum Casting Metals
    Last Post: 09-21-2008, 06:22 AM
  3. Time Stamping CNC Programs
    By kballance in forum Fanuc
    Last Post: 05-27-2008, 09:30 PM
  4. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
    By dsmdude in forum Bending, Forging, Extrusion...
    Last Post: 04-13-2007, 10:01 PM
  5. stamping
    By MBG in forum Bending, Forging, Extrusion...
    Last Post: 10-19-2005, 01:48 PM
