588,240 active members*
4,562 visitors online*
    Nov 2008
    Newbie here-with newly aquired SeriesI
    Just thought I'd say hi. I just purchased a SeriesI 3axis mill (yr=2000) for $1600 and will be in the process of changing it from a 460V configuration to 220V configuration. I intend to power it with a 5hp rotary phase converter.
    I'm not real sharp on the electrical so any advise would be welcome.
    Steve
    Dec 2004
    1865
    Quote Originally Posted by Cameronsa View Post
    Steve
    If it is not cnc, I would yake a real hard look at a 1 to 3 phase VFD. Much nicer and a lot quiter than the phase converter.
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Nov 2008
    Thanks for the reply. It is a CNC which is why I was leaning toward a 3 phase converter. I have rewired the motor from 460v to 220v, changed the jumpers on the transformer, and and made an adjustment on MO1 to 7.4 amps. I am wondering if I need to change out the CR1 relay from 460v to 220v as well?
    Steve
    Feb 2007
    1084
    Steve
    Yeah, don't lick the wires...:rainfro:
    Sounds like you got a good deal on it, throw some power to it and make some $$$!
    most relays have a pretty broad input range. I would just try it unless you already have a 220v relay, then I would probably swap it for the sake of doing things correctly, but honestly, wouldn't suprise me if the 440 relay kicks fine under 220 power.
    Nov 2004
    3028
    There are 2 factors to consider. The coil voltage. Hopefully it is not 440V.
    Secondly the current the relay can tolerate. If you go from 440 to 220 V then typically the current doubles. Hopefully the contacts are rated for that.
    George
  1. Problem With Newly Draw Software- Please Help !!!
    By hubery in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-07-2013, 04:29 PM
  2. First part made on my newly CNC'd X1 :)
    By Memran in forum Benchtop Machines
    Last Post: 04-30-2007, 12:48 AM
  3. Just aquired first mill a Comet 3KV.
    By Jack F in forum Knee Vertical Mills
    Last Post: 10-01-2006, 06:41 PM
  4. My newly repaired B&S Indicator is here!
    By widgitmaster in forum Calibration / Measurement
    Last Post: 08-05-2006, 06:03 PM
  5. Any help for a newbie?
    By Jounik in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-12-2005, 05:12 PM
