587,434 active members*
3,270 visitors online*
IndustryArena Forum > CAM Software > Surfcam > using 4th axis toolpath posts out point to point on A axis?
    Aug 2006
    259
    strange problem, hopefully someone can remedy this.. I'm posting out a 4th axis program, for a fanuc 6m, 3axis simultaneous, and everything is working ok, but the A axis is posting out point to point..
    G01 Z1.75 F0.2500
    A-156.455 F0.5000
    A-154.858
    A-153.263
    A-151.64
    A-150.042
    A-148.418
    A-146.818
    A-145.193
    etc..
    How can I get it to stop that? if it was a small program, I would just edit it out, but we're talking about 10,000+ lines of code..
    I'm using mpost..
    Just when you thought you had it all figured out, all hell breaks loose..
    Aug 2006
    259
    Also, I can't get it to post out 3axis only.. I have 3axis setup in the options, but it's still posting out part of the program with all 4 axis's on one line :/
    Jul 2007
    148
    I think that if you used the arc filter it might make the program smaller and smoother. It should work for the 4th axis too.
  1. point cloud to toolpath
    By adamchapman in forum Mastercam
    Last Post: 11-23-2008, 08:37 AM
  2. VM5 Toolpath starting point
    By Prboz in forum Visual Mill
    Last Post: 11-06-2008, 11:07 PM
  3. Z-axis 0 point (home) ?
    By tvdbon in forum DIY CNC Router Table Machines
    Last Post: 05-26-2008, 08:05 PM
  4. Z Axis Starting Point in DCAD Execute/Simulation
    By jim_stoll in forum Dolphin CAD/CAM
    Last Post: 09-16-2007, 08:08 AM
  5. 2D Toolpath Start Point?
    By mlinder in forum OneCNC
    Last Post: 09-07-2003, 05:28 PM
