586,912 active members*
3,030 visitors online*
    Jan 2007
    12
    DSP pendent -how it works?
    Hello all,
    I have a cnc small mill,which i have made using steppers and mach3.iam quite satisfied with it.now i want to make a small router for my wood carving requirement.
    so the USB-DSP pendent(which is being supplied with all Chinese machines) seems good choice.so i will just make the program in artcam(like software) and dump in to the hand pendent using USB.
    so i wanted to know how feasible to make one?
    does it uses some micro controller?which read the g-code and send step and direction pulses to stepper driver.how does it handle linear and angular interpolations?
    how the system(micro controller) read the data from USB.
    there there any existing open source project like that.
    iam very much interested.
    Pls help
    Jan 2007
    97
    Yes i too interested in this project.
    mean while i have a router with spoiled DSP,does any one know where i can get spare for that?
  1. cnc4pc pendent
    By davidponte in forum Mach Mill
    Last Post: 12-26-2008, 07:28 AM
  2. Tormach MPG Pendent and MACH3
    By Capteod in forum Mach Wizards, Macros, & Addons
    Last Post: 04-23-2008, 02:17 AM
  3. It works!
    By Sleedo in forum CNC Wire Foam Cutter Machines
    Last Post: 12-16-2007, 10:53 PM
  4. Pendent Control Finished
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 11-14-2007, 02:24 AM
  5. Can't Believe It Works!
    By Ursine in forum DIY CNC Router Table Machines
    Last Post: 08-07-2005, 12:46 PM
