587,019 active members*
5,907 visitors online*
    Feb 2008
    Smile Probing cycle ( heidenhain 530 )
    Hi everyone.
    I have a little problem which im sure someone out there could answer for me.
    Ive wrtten a probing cycle for heidenhain 530 where i can place probe anywhere on table and without zeroing the axis will work from this point and return results. In order for this to work i am using the preset table which must be reset to zero before running program. My question is, is there a way to zero the preset table from within a program?
    Regards
    Dominic.
    Yes it can be done except to line 0 of the preset table
    use function 17 syswrite to do it.
  1. Heidenhain iTNC 530 G200(pecking cycle)
    By DULING in forum G-Code Programing
    Last Post: 02-03-2011, 04:27 AM
  2. probing
    By Freddy Bastard in forum Tormach Personal CNC Mill
    Last Post: 08-22-2009, 04:02 AM
  3. Chevalier mill with heidenhain controller won't do datum cycle
    By Kavanthony in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-13-2007, 09:52 AM
  4. Help Tapping Cycle. Coolant off Heidenhain
    By Roni in forum MetalWork Discussion
    Last Post: 03-10-2007, 08:22 AM
