603,344 active members*
3,977 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Radius to end of arc differs from radius to start?
    Nov 2008
    17
    I am getting a g code error. Radius to end of arc differs from radius to start. What can I do? Is there a setting I can increase. r1=1.3046 r2=1.3039. I am using Cam Export to generate the gcode.
    Jamy
    Aug 2007
    7
    You don't have enough precision in your CAM output. You need to get it to add enough places after the decimal. Here are the recommendations in the EMC2 docs:
    http://www.linuxcnc.org/docs/devel/h...view.html#r3_1
    Mar 2004
    370
    Quote Originally Posted by cradek View Post
    Another way to fix this is to set the CAM package to output the radius (R word) instead of incremental offset to arc center (I and J words). (Not all CAM packages have this option.)
    Jon
  1. Replies: 8
    Last Post: 11-15-2009, 01:35 PM
  2. Need help with a radius!!!!
    By dpark1 in forum Solidworks
    Last Post: 04-14-2009, 11:29 PM
  3. Outside radius
    By Shibumi in forum G-Code Programing
    Last Post: 10-30-2008, 04:27 PM
  4. radius help
    By Scott Halstead in forum GibbsCAM
    Last Post: 06-12-2008, 01:27 PM
  5. "Radius to end of arc differs" problems !
    By Geetar-ist in forum G-Code Programing
    Last Post: 12-16-2007, 07:22 PM
