587,661 active members*
3,002 visitors online*
    May 2006
    168
    Multi-pass incrementing X
    Hello,
    Is it possible to increment X on a lathe so that you could have a defined profile and cut off a little at a time cutting back and forth with the Z? Is this a macro function?
    Kind of like the G77 except a profile, not a line...
    Nov 2003
    93
    Cool
    yes it is possible..do it all the time on my lathe..easy if you have a cam program..if you d'ont have a cam program,you can use a series of g77 to remove the maximum material around your profile then do a finishing pass
    on your profile alone which has been converted to G codes with a program like
    dxf2gcode..hope this helps...
    Andy
    May 2006
    168
    Quote Originally Posted by valmet58 View Post
    Thanks for your reply. What cam program do you use?
    All the G77 exampes I find are with a straight line. I will need to experiment....
  1. Each pass different than the previous
    By gage1049 in forum DIY CNC Router Table Machines
    Last Post: 10-22-2008, 09:47 AM
  2. cut depth per pass
    By christ371 in forum Dolphin CAD/CAM
    Last Post: 07-20-2008, 03:14 AM
  3. Multi pass cutting
    By sykic in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-30-2007, 02:52 PM
  4. Heidenhain pass
    By inioxos in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-09-2007, 07:00 PM
  5. Can I run axes at different ipm on the same pass?
    By yorttroy in forum DIY CNC Router Table Machines
    Last Post: 01-04-2006, 07:34 PM
