603,319 active members*
2,949 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Can't remove post line #'s using postform.m
Results 1 to 15 of 15
    Sep 2007
    72
    Does anyone know how to remove line numbers from the Surfcam 2002 post output? I tried playing with the "Sequence#s N 5 5 5" line in the postform.m file with no luck. Can anyone please help?
    PS Even though "First#?" and "Last#?" lines are both set to "N" they are still outputted?
    (I would also like to place a G99 after all G1, G2, and G3 commands without manually editing every line)
    Thank for any and all help.
    Oct 2008
    50
    Quote Originally Posted by MrBoss8 View Post
    Try "Sequence#s N 0 5 5".
    You can try this:
    # Output a safe startup of CDC :
    Infeed
    G<Side> D<DComp> X<H> Y<V> F<FRate>
    G99
    end
    ArcCode
    G[ArcDir] x[h] y[v] Z[D] I[ival] J[jval] F[frate]
    G99
    End
    I havent posted this code out, just throwing ideas out for you.
    DANGER ZONE - HARD HAT REQUIRED!!!!
    Sep 2007
    72
    Jason, thanks for the reply. I tried the "Sequence#s N 0 5 5" (and "Sequence#s N 0 0 0") and the result is "N0" at the beginning of every line. I will be trying your G99 implementation in the next day or 2 and will let you know if it worked.
    Oct 2008
    50
    Can you show the post you are trying to edit? Sounds like you have something else going on. Might be able to help you fix the other stuff you want alot easier.
    Do you have any N[Block] commands in your post?
    If you need something to look at, go under your Help files and in Contents look in MPost Post Processor this will give you some good information.
    Mar 2005
    10
    line numbers
    You're right Jason, either take out the N[Block] code or indent them a couple of spaces to make them inactive.
    nick.
    Sep 2007
    72
    Jason, here is a copy of the post I'm trying to edit:
    name Bridgeport BOSS 8
    % 00
    : 5
    N >4
    V 0
    G >2
    g >2 G
    X ->3.>4
    x ->3.>4 X
    Y ->3.>4
    y ->3.>4 Y
    Z ->3.>4
    z >3.>4 Z IncFrom V
    w >3.>4 Z
    I ->3.>4
    i ->3.>4 I
    J ->3.>4
    j ->3.>4 J
    R ->3.>4
    K ->3.>4
    P >40
    F >3.1 Limit 0.1 100.0
    H >2
    T >2
    M >2
    $ 00
    @ >3.>5
    ^ >3.>5
    S >4 Limit 60 4200
    ' 00
    . 00
    ModalLetters X Y Z R F # List of letters that are modal
    ModalGs 0 1 2 3 73 74 76 80 81 82 83 84 85 # List of g codes that are modal
    Sequence#s N 5 5 5 # Char, freq, incr & start
    First#? N # Y or N 'Output 1st sequence no.
    Last#? N # Y or N 'Output last sequence no.
    HCode X # X or X U 'Horizontal char.
    VCode Y # Y or Y V 'Vertical char.
    Dcode Z # Depth char.
    FeedCode F # Feed rate char.
    Comment ' ' # Begin End comment char.
    Spindle 3 4 5 # Cw, ccw & stop m codes
    Coolant 8 9 7 # On, Off & Mist m codes
    DComp 41 42 40 # Left, Right & Cancel m codes
    LComp 43 49 # On & Off codes
    Feed G1 # Linear move
    Rapid G0 # Rapid positioning word
    Cw G2 # Circular move clockwise
    Ccw G3 # Circular move counter clockwise
    Inc/Abs G 91 90 # Inc & Abs char. & values
    CtrCode I J # I J or R or I J K L
    Helical? N
    Spaces? N # Y or N 'Spaces between words
    Incremental? N # Y or N 'Inc or abs output
    CtrIncremental? N # Y or N 'Inc or abs I & J
    ByQuadrants? N # Y or N 'Break arcs at quadrants
    ZRestart? Y # Y or N 'New cycle if diff. depths
    Work G # Work offset register
    UppercaseComments? Y # Y or N 'Require uppercase comments
    Drill 1 # Drilling canned/manual cycle
    N[Block] G81 V[Vclear] x[H] y[V] z[D] F[FRate]
    N[Block] x[H] y[V]
    end cancel
    Peck 1 # Pecking canned/manual cycle
    N[Block] G87 V[Vclear] x[H] y[V] z[D] w[Vbite] F[FRate]
    end cancel
    Tap 1 # Tapping canned/manual cycle
    N[Block] G84 x[H] y[V] z[D] F[FRate]
    N[Block] x[H] y[V]
    end cancel
    Ream 1 # Reaming canned/manual cycle
    N[Block] G85 x[H] y[V] z[D] F[FRate]
    N[Block] x[H] y[V]
    end cancel
    Bore 1 # Boring canned/manual cycle
    N[Block] G86 x[H] y[V] z[D] F[FRate]
    N[Block] x[H] y[V]
    end cancel
    Back 1 # Back boring canned/manual cycle
    G87 x[H] y[V] z[D] F[FRate]
    x[H] y[V]
    end cancel
    Cancel # Cancel a canned/manual cycle
    N[Block] G80
    end
    StartCode # Start of the program
    :[Program#]
    N[Block] G90 G70 G75
    End
    1stToolChange # First tool change
    N[Block] G0 X[WorkH] Y[WorkV] T[Tool] M6
    N[Block] G0 X[H] Y[V]
    N[Block] S[Speed]
    N[Block] Z[Vclear] M[Cool]
    End
    Infeed # Enable cutter comp
    N[Block] G1 G[Side] X[H] Y[V] F[FRate]
    end
    Outfeed # Disable cutter comp
    N[Block] G1 G40 X[H] Y[V]
    end
    ToolChange # Secondary tool changes
    N[Block] M[CoolantOff]
    N[Block] G0 X[H] Y[V] T[Tool] M6
    End
    EndCode # End of the program
    N[Block] M9
    N[Block] G0 X[WorkH] Y[WorkV] M02
    End
    LineCode # Linear move
    N[Block] G1 X[H] Y[V] Z[D] F[FRate]
    End
    RapidCode # Rapid move
    N[Block] G0 X[H] Y[V] Z[D]
    End
    Cwcode Force? Y # CW circular move
    N[Block] G2 x[H] y[V] i[IVal] j[JVal] F[FRate]
    End
    Ccwcode Force? Y # CCW circular move
    N[Block] G3 x[H] y[V] i[IVal] j[JVal] F[FRate]
    End
    REPLACE "N5G90" WITH ".N5G90"
    replace "x" with "X"
    replace "y" with "Y"
    Replace "@" with "Tool Diameter "
    Replace "^" with " Corner Radius "
    Replace "$" with " '""
    Oct 2008
    50
    Sequence#s N 0 5 5 # Char, freq, incr & start (CHANGE LINE TO THIS)
    N[Block] (REMOVE ALL INSTANCES)
    G99 (ADD)
    End
    G99 (ADD)
    End
    G99 (ADD)
    End
    These are the changes I made and it worked to your original request.:cheers:
    If you PM your email address, I'll send you the postform.m file.
    Sep 2007
    72
    Hello Jason, The following files are the output produced and the post you sent me. Line #'s are gone but the G99 command appears on a separate line by itself, not after a G1, G2, or G3 as is needed. Can you see anything that may cause this?
    Thanks again.
    post output:
    :00001
    G90G70G75
    ID DELETED
    G0X0Y0T3M6
    G0X-0.5183Y0.3281
    S4000
    Z0.5M8
    G0Z0.25
    G1Z-0.01F15.0
    G99
    G1X0.5183
    G99
    G2X0.5356Y0.308I0.5183J0.3106F15.0
    G99
    G2X0.4332Y0.124I0.2413J0.3513F15.0
    G99
    G3X0.3202Y-0.0237I0.6882J-0.1882F15.0
    G99
    G1X0.3633Y-0.0237
    G99
    G2X0.4178Y-0.0501I0.3636J-0.0924F15.0
    G99
    G2X0.4213Y-0.0633I0.404J-0.0609F15.0
    G99
    G1X0.6427Y-0.0633
    G99
    G2X0.6602Y-0.0808I0.6427J-0.0808F15.0
    G99
    G1X0.6602Y-0.1007
    G99
    G2X0.6421Y-0.1182I0.6427J-0.1007F15.0
    G99
    G3X0.1109Y-0.1945I0.5885J-1.6322F15.0
    G99
    G1X0.1109Y-0.2223
    G99
    G2X0.1448Y-0.3052I-0.4355J-0.4934F15.0
    G99
    G2X0.1281Y-0.3281I0.1281J-0.3106F15.0
    G99
    G1X-0.1281Y-0.3281
    G99
    G2X-0.1448Y-0.3052I-0.1281J-0.3106F15.0
    G99
    G2X-0.1109Y-0.2223I0.4355J-0.4934F15.0
    G99
    G1X-0.1109Y-0.1945
    G99
    G3X-0.6421Y-0.1182I-0.5885J-1.6322F15.0
    G99
    G2X-0.6602Y-0.1007I-0.6427J-0.1007F15.0
    G99
    G1X-0.6602Y-0.0808
    G99
    G2X-0.6427Y-0.0633I-0.6427J-0.0808F15.0
    G99
    G1X-0.4213Y-0.0633
    G99
    G2X-0.4178Y-0.0501I-0.404J-0.0609F15.0
    G99
    G2X-0.3633Y-0.0237I-0.3636J-0.0924F15.0
    G99
    G1X-0.3202Y-0.0237
    G99
    G3X-0.4332Y0.124I-0.6882J-0.1882F15.0
    G99
    G2X-0.5356Y0.308I-0.2413J0.3513F15.0
    G99
    G2X-0.5183Y0.3281I-0.5183J0.3106F15.0
    G99
    G1X-0.5183Y0.3261
    G99
    G1X0.5183
    G99
    G2X0.5336Y0.3083I0.5183J0.3106F15.0
    G99
    G2X0.4319Y0.1256I0.2413J0.3513F15.0
    G99
    G3X0.3171Y-0.0257I0.6882J-0.1882F15.0
    G99
    G1X0.3633Y-0.0257
    G99
    G2X0.4162Y-0.0513I0.3636J-0.0924F15.0
    G99
    G2X0.4188Y-0.0653I0.404J-0.0609F15.0
    G99
    G1X0.6427Y-0.0653
    G99
    G2X0.6582Y-0.0808I0.6427J-0.0808F15.0
    G99
    G1X0.6582Y-0.1007
    G99
    G2X0.6422Y-0.1162I0.6427J-0.1007F15.0
    G99
    G3X0.1089Y-0.1931I0.5885J-1.6322F15.0
    G99
    G1X0.1089Y-0.2227
    G99
    G2X0.1429Y-0.3058I-0.4355J-0.4934F15.0
    G99
    G2X0.1281Y-0.3261I0.1281J-0.3106F15.0
    G99
    G1X-0.1281Y-0.3261
    G99
    G2X-0.1429Y-0.3058I-0.1281J-0.3106F15.0
    G99
    G2X-0.1089Y-0.2227I0.4355J-0.4934F15.0
    G99
    G1X-0.1089Y-0.1931
    G99
    G3X-0.6422Y-0.1162I-0.5885J-1.6322F15.0
    G99
    G2X-0.6582Y-0.1007I-0.6427J-0.1007F15.0
    G99
    G1X-0.6582Y-0.0808
    G99
    G2X-0.6427Y-0.0653I-0.6427J-0.0808F15.0
    G99
    G1X-0.4188Y-0.0653
    G99
    G2X-0.4162Y-0.0513I-0.404J-0.0609F15.0
    G99
    G2X-0.3633Y-0.0257I-0.3636J-0.0924F15.0
    G99
    G1X-0.3171Y-0.0257
    G99
    G3X-0.4319Y0.1256I-0.6882J-0.1882F15.0
    G99
    G2X-0.5336Y0.3083I-0.2413J0.3513F15.0
    G99
    G2X-0.5183Y0.3261I-0.5183J0.3106F15.0
    G99
    G0X-0.5183Y0.3261Z0.5
    X0.1159Y0.2264
    Z0.25
    G1Z-0.01
    G99
    G1Y-0.0281
    G99
    G1X0.1723
    G99
    G2X0.2295Y0.1397I0.7094J-0.1177F15.0
    G99
    G3X0.2618Y0.2323I-0.0179J0.2779F15.0
    G99
    G1X0.2393Y0.2264
    G99
    G1X0.1159
    G99
    G1X0.1139Y0.2284
    G99
    G1Y-0.0301
    G99
    G1X0.174
    G99
    G2X0.2313Y0.1387I0.7094J-0.1177F15.0
    G99
    G3X0.2643Y0.235I-0.0179J0.2779F15.0
    G99
    G1X0.239Y0.2284
    G99
    G1X0.1139
    G99
    G0Z0.5
    X-0.1159Y-0.0281
    Z0.25
    G1Z-0.01
    G99
    G1Y0.2264
    G99
    G1X-0.2393
    G99
    G1X-0.2618Y0.2323
    G99
    G3X-0.2295Y0.1397I0.0179J0.2779F15.0
    G99
    G2X-0.1723Y-0.0281I-0.7094J-0.1177F15.0
    G99
    G1X-0.1159Y-0.0281
    G99
    G1X-0.1139Y-0.0301
    G99
    G1Y0.2284
    G99
    G1X-0.239
    G99
    G1X-0.2643Y0.235
    G99
    G3X-0.2313Y0.1387I0.0179J0.2779F15.0
    G99
    G2X-0.174Y-0.0301I-0.7094J-0.1177F15.0
    G99
    G1X-0.1139Y-0.0301
    G99
    G0Z0.5
    M9
    G0X0Y0M2
    postform.m file:
    % 00
    : 5
    N >4
    V 0
    G >2
    g >2 G
    X ->3.>4
    x ->3.>4 X
    Y ->3.>4
    y ->3.>4 Y
    Z ->3.>4
    z >3.>4 Z IncFrom V
    w >3.>4 Z
    I ->3.>4
    i ->3.>4 I
    J ->3.>4
    j ->3.>4 J
    R ->3.>4
    K ->3.>4
    P >40
    H >2
    T >2
    M >2
    $ 00
    @ >3.>5
    ^ >3.>5
    S >4 Limit 60 4200
    ' 00
    . 00
    First#? N # Y or N Output 1st sequence no.
    Last#? N # Y or N Output last sequence no.
    Helical? N
    x[H] y[V]
    end cancel
    end cancel
    x[H] y[V]
    end cancel
    x[H] y[V]
    end cancel
    x[H] y[V]
    end cancel
    x[H] y[V]
    end cancel
    G80
    end
    :[Program#]
    G90 G70 G75
    End
    G0 X[H] Y[V]
    S[Speed]
    Z[Vclear] M[Cool]
    End
    end
    G1 G40 X[H] Y[V]
    end
    M[CoolantOff]
    Z[Vclear] M[Cool]
    End
    M9
    End
    G99
    End
    G0 X[H] Y[V] Z[D]
    End
    G99
    End
    G99
    End
    Oct 2008
    50
    Easy fix, just move the G99 to where you need it. I assumed "after" was on another line and not directly after. I sent you an updated post.
    Sep 2007
    72
    SO CLOSE !!
    Jason, its "SO CLOSE" to being perfect! The only problem is a G99 appearing on G1 Z moves. (For whatever reason this sends the spindle down to crash?)
    How close would the following be to a fix:
    G1 G99 X[H] Y[V] F[FRate] # removed " Z[D]"
    End
    G1 Z[D] F[FRate] # Z[D] by itself (no G99, or X, or Y)
    (Can "LineCode" appear more than once?)
    A sample of the output follows: (the lines in question are marked with **********)
    :00001
    G90G70G75
    G0X0Y0T1M6
    G0X-0.0257Y0.1046
    S4000
    Z0.25M8
    G1G99Z-0.01F15.0 **********
    G2G99X0.0068Y0.1255I-0.0009J0.1017F15.0
    G2G99X0.0417Y0.0852I0.0048J0.0885F15.0
    G2G99X0.0202Y0.05I-0.0028J0.0882F15.0
    G2G99X-0.0061Y0.05I0.0071J0.0644F15.0
    G2G99X-0.0179Y0.0675I0.0039J0.0694F15.0
    G1G99X0.033Y0.065
    G0Z0.25
    X-0.0257Y0.1046
    Z0.24
    G1G99Z-0.02 ********** (? no feedrate after 1st occurrence?)
    G1G99X0.033Y0.065
    G0Z0.25
    X-0.0257Y0.1046
    Z0.23
    G1G99Z-0.021 **********
    G1G99X0.033Y0.065
    G0Z0.25
    X-0.0257Y0.1046
    Z0.229
    G1G99Z-0.023 **********
    Thanks Again.
    Oct 2008
    50
    No problem to fix.
    Sent updated postform.m.
    Sep 2007
    72
    After putting more spaces between LineCode and # Linear move, output seemed to be correct, but have not yet had time to test consistency but, things look good so far.
    Jason, Thanks for the help
    Oct 2008
    50
    No problem, any other issues just let me know, you have my e-mail.
    Good luck.:cheers:
    Jul 2022
    Re: Can't remove post line #'s using postform.m
    Quote Originally Posted by Jason S View Post
    Good luck.:cheers:
    Hi sir jason
    Can you please help with this. Modifying postform m Converting this G codes
    G83 X10. Y10. Z-10 R1. Q.8 F100.
    Y-10.
    X-10.
    Y10.
    to this code (heidenhain iso format)
    G83 X10. Y10 P01 1. P02 -10 P03 .8 P05 100.
    Y-10. G79
    X-10. G79
    Y10. G79
    Note: G79 is the call cycle for heidenhain control, it needs to be written in every location of drilling cycle so that the heidenhain will do the peck drilling otherwise if the control doesnt read the G79 it will only travel to does location w/o peck drilling.
    Thanks in advance
    Keep safe.
    Apr 2025
    Ah, bummer! Isso acontece às vezes com software, né? Espero que consiga resolver isso logo. Às vezes, reiniciar o programa ajuda, ou procurar algum tutorial online. Boa sorte!https://grade-calculator.top/
  1. Hass VF-5 post arc/line interpolation problem
    By meadowtech in forum FeatureCAM CAD/CAM
    Last Post: 06-11-2008, 02:06 PM
  2. Line Smoothing, point /line no identification
    By dz1 in forum Visual Basic
    Last Post: 12-15-2007, 12:03 PM
  3. Postform.m
    By moldcore in forum Surfcam
    Last Post: 04-05-2006, 02:16 PM
