We upgraded our controler from cn10 to cn12 and had to upgrade cadcode, keep getting an error at the machine mw310 error. Does anyone have the machine specs or the configuration file from cadcode that works. we are using cadcode7. Thanks!
Where are you guy?
__________________________________________________ ____
Hi Joe
I cant help you because i have a 320 with CN10 and mw309, but i am curious about the reason for someone to upgrade to CN12 and go to mw310, is it so big difference?
Have you contact with Masterwood to find the controler and CN12 because a friend of mine needs to upgrade his CN6 in a quite old 302 (i think), and he doesnt now if it worth the cost for he's old machine.
Joe
I'm a new member to CNC Zone I have been working on Masterwood machine for 9 years you can contact me at lrhtecser.com
lrhtec
can i turn on wood master with out compiuter conected?
I have masterwood 313 if any one want information about this model i could help.
Do you hava a manual that you can send to me? I have a 309 and no manual it gives now an error.
Have you to a complet copy of the software on the harddrive of the 313? I like to have that to.
Thanks -> info@mvanvliet.nl
Good day.Is the 313 similar to the 317?
I have a Masterwood Project 317.I need to reset the head
To zero for the xyz axis.Is there a technical manual available
please?parameters?any information would be very much
appreciated.
Thank you
Memo
