603,308 active members*
3,264 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Autocad LT 2008 Total inches in drawing?
    Jun 2008
    8
    I have searched for a method of getting the total measurement of lines in my drawings and found LISP to be the simplest method but also that my LT version does not support LISP. I am trying to find a way to get the total length of the lines in a draft so that I can calculate times based on an IPM (Inches Per Minute) multiplied by the total length of all lines within the drawing.
    I would appreciate ANY help you guys can offer. Thanks in advance.
    Gawker
    ETA - I'm drafting for ESAB machines and using Columbus for the machines just in case anyone here is similarly equipped and knows of a way to access the same information from THAT software rather than AutoCAD itself. Thanks again.
    35494
    Jan 2020
    7
    Re: Autocad LT 2008 Total inches in drawing?
    Quote Originally Posted by Gawker View Post
    Gawker
    the information can be provided within the columbus software , under printfunctions detailed calculation
  1. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
  2. With AutoCad Drawing.
    By Stampede in forum BobCad-Cam
    Last Post: 02-18-2009, 07:45 AM
  3. How too, AutoCad drawing to BMP/JPEG
    By Holmes_ca in forum Autodesk
    Last Post: 02-17-2009, 04:05 PM
  4. join lines, Autocad 2008
    By vividdezigns in forum Autodesk
    Last Post: 10-27-2008, 11:00 PM
  5. autocad 2d/3d drawing/render into partmaster?
    By BulleTxMagneT in forum Dolphin CAD/CAM
    Last Post: 01-28-2008, 03:39 PM
