586,655 active members*
4,086 visitors online*
    Angry MillTurn Memory Problem
    We have a older (1991) Hitachi Seiki HiCell MillTurn. Here is our problem:
    When someone downloads a program from the DNC into the control and they name it with the 1st number being a 9 in the program number (ex: O9054), we can't delete or modify that program anymore. It stays in the control. No one we've talked to can figure out why we can't delete it. I've tried to change the program number to something else (ex: 5182) and it won't let me. You can't even modify the rest of the program. It's locked for some reason. When someone downloads a program without a 9 as the first number, they can edit the program like normal.
    Anyone have any ideas or suggestions?
    Thanks in advance,
    Sean
    Mar 2005
    76
    Its a locked program. If its a Fanuc control there is a parameter to unlock the 9000 numbers.
    It's possible that it has the Fanuc control. But the rest of the MillTurns we have are a few years newer and all have the Seicos LIII control. I'm not allowed in the control cabinet to see what boards are in there... If anyone has a phone number for Hitachi or Mori that would be great!
    Feb 2009
    6028
    hitachi
    Fanuc most likely
    NE9 locks the macro programs. O9XXX would indicate macro programs. Don't ever use a O9XXX unless you are choosing a macro.
    parameter 3202 bit 4
    Thanks Tire! I'll give that a try tonight at work.
  1. Memory problem
    By Michael82 in forum Fadal
    Last Post: 10-15-2009, 03:16 PM
  2. memory card problem on robodrill
    By aimcnc in forum Fanuc
    Last Post: 03-20-2009, 10:38 PM
  3. Mazak VTC 41 memory problem
    By kamran67 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-07-2008, 12:57 PM
  4. Program Memory problem in FANUC 0i Mate MC
    By ranjankrana in forum Fanuc
    Last Post: 01-10-2008, 10:34 AM
  5. hyperMILL millTurn module
    By Alan L in forum Hypermill
    Last Post: 01-02-2007, 02:33 PM
