603,891 active members*
6,357 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > 4th axis tabletop mill projects
    Sep 2007
    182
    I'm looking to add a 4th axis to my tabletop mill and tried searching for some projects done by other members but didnt find too much. Has anyone come across other projects/builds where a 4th axis was added? Or just have some recommendations?
    So far I think the best way to accomplish this is a rotary table, with a lathe type collet to hold projects centered. On the right track?
    Sep 2006
    135
    Depending on the quality of the rotary table, backlash may be a problem. I recently completed a 4th axis conversion using a mini-lathe headstock. This works out well and is a simple design. I raised it to match a tailstock that I already had.
    **I attached couple of photos, but they seem not to be here. Will try again.**
    Sep 2006
    135
    Let's try again.Click image for larger version.
    May 2005
    2502
    Check this thread:
    http://www.machsupport.com/forum/ind...c,11422.0.html
    Watch all his videos. Very cool stuff!
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
  1. IH Mill Projects
    By IHCNC in forum Charter Oak Automation Support Forum
    Last Post: 12-31-2009, 08:58 PM
  2. 3 projects of CNC Router 3Axis, 4 Axis and 5 Axis
    By LuthierX in forum Uncategorised MetalWorking Machines
    Last Post: 07-07-2008, 02:26 AM
  3. 3 projects of CNC Router 3Axis, 4 Axis and 5 Axis
    Last Post: 02-25-2008, 04:12 PM
  4. I need projects mill and lathe
    By harolda in forum Employment Opportunity
    Last Post: 05-26-2005, 10:51 PM
  5. Projects For 3-axis Mini-mill
    By moose in forum Community Club House
    Last Post: 03-24-2004, 06:57 PM
