603,415 active members*
2,626 visitors online*
IndustryArena Forum > CAM Software > Mastercam > where can I find the the quick mask lines and arcs icon.
    Mar 2008
    377
    I am trying to do some surface machining?
    here is my question I am reading this book mastercam mill 3 and I am doing a glass shape but I am stuck when it tells me to select the quick mask lines and arcs icon.
    where do I find it or how can I enable it so I can have the quick mask lines and arcs icon. on the screen.
    Dec 2008
    3212
    On a standard install with no mods
    It's on the Right hand margin under the listing of the last used commands
    Another method is to use the filter mask,
    --- select only pull-down on the upper taskbar ( just above the screen near center )
    ---and place a check on arcs ( if more selections required, hold Crtl key down to place extra checks..... you can also use the additional filters--color, level etc ) your mouse can only select entities that meet the mask critria. To cancel the setting, use the same pull-down and click the red circle with diagonal bar
    If, at any stage your screen loses taskbars, right-click in an open area in the upper icon area and re-load a toolbar state ( play with it and familiarise yourself with how it works, you cannot stuff this up unless you save a toolbar state after customising )
  1. Lines & Arcs Not Showing Up
    By XxLT250RxX in forum Mastercam
    Last Post: 10-12-2013, 06:52 PM
  2. Converting lines to arcs?
    By Fleck in forum Rhino 3D
    Last Post: 03-14-2009, 06:47 PM
  3. Tangent lines joining two arcs
    By yongchiprsnapr in forum Mastercam
    Last Post: 11-30-2008, 11:39 PM
  4. points to lines/arcs
    By vmax549 in forum Autodesk
    Last Post: 10-14-2008, 02:05 PM
  5. lines-arcs vs spline problem
    By metlcutr55 in forum Uncategorised CAM Discussion
    Last Post: 07-07-2006, 04:16 PM
