588,563 active members*
4,855 visitors online*
    Jan 2009
    39
    Question System Variable For Pallet In The Machine
    Gentlemen
    I have a Mazak Nexus 6000 Horizontal and I want to know if there is a system variable to monitor what pallet is in the machine? Thank You
    Jun 2008
    1511
    You will probably have to refer to the MTB manual to see if one was setup to track this. How many pallets do you have?
    Stevo
    Apr 2009
    22
    We used to edit the M61&M62 macro for pallet changes. We added a statement like below. This way we could set-up safeguard commands to ensure the correct program was run on the right pallet.
    Some HMC's I've worked on had M code form the manufacturer already did this.m Very Handy.
    ou812
    M61 Macro
    #701=1. (PALLET #1)
    M62 Macro
    #701=2.(PALLET #2)
    Jan 2010
    #51997 variable number for current pallet with FUSION control
  1. Dry-run system variable?
    By machzero in forum Okuma
    Last Post: 05-21-2015, 01:13 PM
  2. System Variable Z Work Shift
    By ggborgen in forum Parametric Programing
    Last Post: 11-26-2009, 06:57 AM
  3. System variable #4113 for M-code
    By sinha_nsit in forum Fanuc
    Last Post: 10-14-2009, 05:03 PM
  4. System Variable for Pallet location
    By Jason812 in forum Fanuc
    Last Post: 11-05-2007, 02:23 PM
  5. Multi pallet machining system...??
    By REVCAM_Bob in forum MetalWork Discussion
    Last Post: 02-09-2007, 02:18 AM
