587,787 active members*
2,905 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Sieg X3 vs X4 for 304 stainless?
Results 1 to 14 of 14
    Mar 2008
    52
    Planning on a cnc conversion, but im not sure what can be milled on the X3.
    Have anybody tried to mill stainless or titanium on their X3 mill? Im not planning on just milling stainless, but I want the capacity to do work using tungsten carbide tools and low feeds.
    Mar 2009
    296
    Quote Originally Posted by slektning View Post
    I don't know much about milling stainless and titanium but I'm sure a X3 someone did a good job converting can do whatever a X4 can do. I think with all the money you save buying an X3 instead of an X4 you can probably get really high end stuff to make your X3 better than an X4.
    Jul 2005
    969
    i can tell you from experience that 304 is "doable" but far from easy on a machine like the x3 or x4 ...well at least not on a syilx4 unless you want to kill it fast 303 was not as bad but it was still pretty hard on the overall machine and this is with feed rate of +/- 1.5 ipm as for other material such as aluminium, brass and soft to medium hardness steel was not as bad
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
    Mar 2008
    52
    The x4 im reffering to is the new standard sieg X4 non cnc
    Dont think its out yet, but im not sure.
    What about a converted Sieg X3 with the aussie kit?
    Is the super x3 Worth the extra money when converting it?
    Jun 2007
    3891
    i like the look of that. 8x20" travel, very beefy frame. 1hp motor, mt4 taper. has the net tapered gibs from the kx3. i wonder if this means a kx4 is on the way.
    Jun 2007
    3891
    looked up some more and it seems to be siegs version of the RF45. very similar to the grizzly g0519, but not quite identical. the grizzly is $1700.
    http://www.grizzly.com/images/pics/jpeg500/g/g0519.jpg
    Mar 2009
    296
    That explains it.
    Jul 2004
    1424
    wow, that looks pretty cool. It looks like a 2/3 size RF45, rather then a souped-up mini-mill. They got rid of the awkward z-axis handcrank which had a poor mechanical advantage on the X3 and put the z-axis handle on the column where it is on the RF45. Now if they would just make a version with a built-in z-axis power feed like the Grizzly G0484...
    You can see the specs now on siegind site (so it is not just an aussie thing):
    http://www.siegind.com/product.php?id=4
    That is going to make the confusion worse, since people are going to confuse the syil x4 with the sieg x4. And if sieg cnc'd it....
    Jul 2005
    969
    i dont know but for me a speed range that is limited to 1600 is no good, all small machine in my point of view should atleast do 5k to 6k
    Jun 2007
    3891
    Quote Originally Posted by ataxy View Post
    its not really that small a machine, but i agree. there are many rf45 varians with 3000+rpm spindles. it is somewhat cheaper than many of the other rf45's though at $1360us shipped from china (plus duties and tax).
    ive actually kinda lost interest in it already and am drifting over to the weiss/opti WMD30LV type machines and "big" IH type rf45's.
    Mar 2008
    52
    Wouldnt it be easy to install a 3phase standard industrial motor of 1,5-2Kw and use a frequency converter on it to get higher revs? (Im an electrician and we got tons of that stuff where I work)
    Oct 2009
    3
    Has anybody tried the X4 yet, is it a good machine
    Jul 2005
    969
    Quote Originally Posted by mp409mm View Post
    the x4+ is the same as the x4 with more gadget so what you can read about the x4+ applyes to the x4
    Oct 2009
    3
    mp409mm
  1. Sieg KX3 VS DIY X3 CNC
    By DonF in forum Benchtop Machines
    Last Post: 12-01-2010, 06:19 AM
  2. Sieg X2 or X3?
    By david_geng in forum Benchtop Machines
    Last Post: 01-12-2007, 07:58 PM
  3. Help! What is Sieg X1, X2, X3?
    By cjchands in forum Benchtop Machines
    Last Post: 10-12-2006, 11:20 AM
  4. Sieg X2 and X3
    By rozon in forum Benchtop Machines
    Last Post: 05-05-2006, 02:23 PM
  5. Sieg X3
    By motomitch1 in forum Benchtop Machines
    Last Post: 09-22-2004, 02:03 AM
