587,821 active members*
2,841 visitors online*
    Jul 2004
    93
    SL 15 Parameter resetting
    Hello all, Just brought home a sl15 from work for a small fee, a year ago 1 of the employees erased the parameters from memory, and they were unable to reinstall them.
    As I was reading the the book it said you have to use the internal toogle
    switch to be able to enter all parameters.in the control.but dose not clearly show how this is done , I have the list and when I tried the lathe was at work there were a few pages that would not except the parameters.
    Now I feel this is all that needs to be done as it was running the moment before he deleted the parameters instead of programs
    any help would be appreciated
    thanks Brad
    IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH
    Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust.
    Jul 2005
    12177
    You have the list of parameters but not the floppy disk that comes with the machine?
    Did you know that all the parameters are on a disk somewhere?
    Have you looked inside the control cabinet? On my lathes the disk with the parameters was in a pocket inside the door; on some lathes it is still there.
    Incidentally a reason that you cannot enter some parameters could be that they are options and you need a code number.
    Jul 2004
    93
    Geof Thanks for the reply , the disc is long gone as i am the last of who knows how many owners, the machine is moving but not in right direction and need to work on home positions, a some parameters the get entered in the bit pages dont remember exactly which one but working on getting the elec hooked up now.
    Brad
  1. Resetting X0 Y0 Z0.
    By Witsenburg in forum Mach Software (ArtSoft software)
    Last Post: 06-05-2007, 03:39 PM
  2. Resetting the top view ?
    By altered in forum Mastercam
    Last Post: 03-17-2007, 10:03 PM
  3. Mach keeps resetting
    By Moondog in forum Machines running Mach Software
    Last Post: 08-16-2006, 01:57 AM
  4. Zero location resetting mid-run
    By esmiller in forum Machines running Mach Software
    Last Post: 03-03-2006, 09:00 PM
  5. resetting fields
    By hogman in forum GibbsCAM
    Last Post: 05-06-2005, 02:22 AM
