603,370 active members*
3,835 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > smoothstepper stops mach3 after 460 lines
Results 1 to 8 of 8
    Oct 2010
    9
    Just got a new USB Smoothstepper and am trying to set it up on a spare
    system. the system is Intel core2, windows 7, and Mach3 ver 3.043.040,
    v17f & 2.08.24 SS drivers. I have the SS just setting next to the computer
    and nothing is attached but the USB cable. I have the drivers installed and
    it is comunicating fine. If I run a G code file mach3 will take off and run to line
    460-- 485 range and then stop. The lites on SS are still on and proper.
    If I tell it not to use SS and use the parallel port with the SS still plugged in
    Mach3 runs fine, will run to end of all G-code programs.
    I have tried to change the setting in the SS plugins in Mach3 but to no avail.
    I have tried Mach3 ver 066, same thing. Have turned off all programs in windows
    that are not needed. Have tried different Gcode files, still stops in the 460--489 range
    of lines
    Any Help ?????
    Jan 2005
    15362
    Robert Fon
    Sounds like you have not installed the Mach 3 license, Mach 3 will only run up to 500 lines without the license being installed
    Mactec54
    Jan 2010
    2141
    I do not have the same setup that you have, and maybe this is obvious, but I'll suggest it anyway.
    The unlicensed mode of Mach3 is limited to 500 lines of Gcode.
    Is it possible that somehow Mach3 thinks that it is running in unlicensed mode and is cutting you off as you approach 500 lines?
    Oct 2010
    9
    Smoothstepper stoops Mach3 after 460 lines
    Problem is not lic file, mach3 will run to the end of 24000 lines of code if the
    smoothstepper is not used, in other words using the parallel port.
    Have tried various other gcode files and still does same thing.
    Mar 2003
    35494
    Is there a message when it stops?
    What is the gcode where it stops?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2010
    9
    smoothstepper stops mach3 at line 460
    There are no messages displayed in Mach3. Here is a sample section of G-code that it stops at in one program. the line it stops on is 474 in this case.
    N4660G1X10.0711Y2.4574Z-0.3196
    N4670G1X10.0814Y2.4660Z-0.3123
    N4680G1X10.0967Y2.4763Z-0.3039
    N4690G1X10.1051Y2.4809Z-0.3017
    N4700G1X10.1229Y2.4879Z-0.2965
    N4710G1X10.1642Y2.5014Z-0.2927
    N4720G1X10.1988Y2.5154Z-0.2895
    N4730G1X10.2091Y2.5206Z-0.2888
    N4740G1X10.2194Y2.5258Z-0.2891 <-----Here
    N4750G1X10.2298Y2.5310Z-0.2884
    N4760G1X10.2477Y2.5422Z-0.2871
    N4770G1X10.2567Y2.5478Z-0.2875
    N4780G1X10.2797Y2.5653Z-0.2869
    N4790G1X10.3001Y2.5842Z-0.2863
    N4800G1X10.3074Y2.5925Z-0.2871
    N4810G1X10.3147Y2.6009Z-0.2866
    N4820G1X10.3211Y2.6098Z-0.2859
    Nothing special about it.
    I just ran it again and turned on the logging in the mach3 plugin and
    noticed that it had a number like 947 that was fairly consistant in the
    box that is labeled buffer-- until it gets to the line 474 and then it is 0.
    Not sure what that is all about but it may be the problem.
    Dec 2005
    238
    Sounds very strange indeed.
    The USB smooth stepper is known to stop working but when it does it crashes and burns. Nothing short of and closing Mach3 and restarting will get it working again. What you are experiencing sounds very strange.
    If it helps I have mach3 and a USB smooth stepper it you would like to post a file with the first 1000 lines or so I will run do an air cut of it on my machine and see if it runs right through or stops at the same point as yours.
    Cheers
    Peter
    The ingenuity of idiots is unlimited.
    http://www.youtube.com/user/cncnutz
    Jan 2009
    265
    Mach 3 licensing issue.
  1. Problems with Mach3/SmoothStepper
    By JJDennon in forum LinuxCNC (formerly EMC2)
    Last Post: 04-26-2012, 03:31 PM
  2. Mach3 Plugin for Ethernet Smoothstepper
    By dwilson26 in forum SmoothStepper Motion Control
    Last Post: 01-31-2012, 07:35 PM
  3. Replies: 2
    Last Post: 08-08-2011, 03:30 PM
  4. Mach3 + SmoothStepper + G540 = No go
    By CarbonKevin in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2009, 12:09 AM
  5. SmoothStepper and Mach3 setup
    By jeffmorris in forum Mach Software (ArtSoft software)
    Last Post: 09-02-2008, 09:09 PM
