588,439 active members*
5,285 visitors online*
Results 1 to 4 of 4
    Dec 2010
    82
    Soft Limits & Limit Switches
    Finally got my Shoptask 3-In-1, 1993 model 17-20 XMTC, restored and working on all three axis's! (Only took me two years!) LoL. Now I have to ask some "newbie" questions about Mach3. Do I have to have limit switches to set up soft limits to keep from accidentally hitting the chuck or tail stock? Thanks
    Nov 2008
    17
    Nope, you don't have to have "hard" limit switches to use soft limits. But you should have at least homing switches to reference somehow your soft limits. That's what I have and it works like charm. One switch per axis, all NC in series used as homing (optionally also as one side limit) switches. Then soft limits turn on. When you power up, reference all your axis and you are set.
    Dec 2010
    82
    Unhappy
    Quote Originally Posted by Foogl View Post
    Thanks Foogl for your post.
    Uh Oh! Now more confusion comes to roost! I read the manual "but" obviously I'm lost in CNC jargin world. "NC in series?" Are they hard switches or software config switches? Oooooh, my tiny brain is going to explode! LoL :drowning:
    Homing
    I would check the the people at Shop Task and see what pins, if any, you can use for each axis for homing and limits on your parallel port connection. I would think you may have to upgrade your parallel port connection to an updated breakout board. Maybe you could post a picture of your current parallel port connection so the guys here could see what you have.
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
  1. Okuma soft limits
    By Carlton Jenkins in forum Okuma
    Last Post: 08-22-2012, 05:18 PM
  2. soft limits?
    By Justin Cavender in forum DIY CNC Router Table Machines
    Last Post: 03-15-2011, 12:36 PM
  3. Backing off home switches in Mach 3 with soft limits?? Gerry??
    By jbluetooth in forum DIY CNC Router Table Machines
    Last Post: 09-29-2009, 09:47 PM
  4. soft limits
    By zimba43 in forum Mach Mill
    Last Post: 04-01-2008, 10:18 PM
  5. Question about Soft Limits???
    By Dennis Fletcher in forum Mach Software (ArtSoft software)
    Last Post: 07-31-2005, 07:07 PM
