587,982 active members*
5,604 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle just stopped spinning.... cnc
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Dec 2003
    24220
    Re: Spindle just stopped spinning.... cnc
    Quote Originally Posted by ericks View Post
    the firmware is dodgy, the electronics although good quality is very basic in design/protection.
    They are still learning the lessons the main manufacturers/designers learnt long ago
    I read that many Chinese VFD manuf are building around a Japanese processor designed for VFD applications.
    Maybe the weakness is in the application of it?
    Al.
    Albert E.
  2. #22
    ericks Guest
    Quote Originally Posted by Al_The_Man View Post
    Al.
    I contacted them just to let them know that their drive has a dangerous defect....their advise to me was to reduce the dec time to one second
  3. #23
    Jan 2005
    15362
    They probably did not understand what you where saying, English to Chinese does not translate very well, so it probably came out like your VFD eats goats cheese
    Your VFD is totally different to the one being discussed here, I have more than 60 VFD Drive manuals and there Tec information and your one is not in the list, there are so many to choose from why buy one that is not well known
    Mactec54
  4. #24
    ericks Guest
    Guess i was curious...saw a video of someone using one, and it's cheap! Also it's compact size....i know mine is different but it's also cheap Chinese like the one discussed here
    That said, i will most likely use it in my new machine
  5. #25
    Dec 2003
    24220
    I recently contacted the Huanyang factory and was referred over to what apparently was technical support, the videos sent were very amateurish and crude, they also sent a library of manuals, but I sort of got the impression that the factory just operated at the design/manuf level and any tech support was handed over to some who were not that technically minded. IOW one did not really know what the other was doing!
    Al.
    Albert E.
Page 2 of 2 12
  1. Spindle won't start spinning on Multicam
    By lettersetc in forum EnRoute
    Last Post: 09-23-2015, 09:32 PM
  2. X6-1500GT - Spindle not spinning
    By Demanth in forum Chinese Machines
    Last Post: 11-22-2014, 05:11 PM
  3. Spindle spinning in reverse
    By SwampDonkey in forum Tormach Personal CNC Mill
    Last Post: 09-29-2014, 02:39 AM
  4. How many rpm's is this spindle spinning?
    By Apples in forum Uncategorised MetalWorking Machines
    Last Post: 03-14-2008, 08:40 PM
  5. Spinning a Bridgeport Spindle to 5-6K??
    By snakebit95 in forum Bridgeport / Hardinge Mills
    Last Post: 02-08-2006, 11:08 PM
