587,729 active members*
3,383 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Spindle refrigerant leaking somewhere
Results 1 to 5 of 5
    Aug 2008
    132
    Question Spindle refrigerant leaking somewhere
    1995 4020HT. Just filled the spindle refrigerant tank with 50/50 distilled water / Dowfrost. Next day its almost empty. I can't seem to see where its leaking - no puddles or evidence of a leak anywhere.
    Is there a common place to look??
    Jun 2004
    511
    Re: Spindle refrigerant leaking somewhere
    Add some dark food coloring dye and go 75/25 water/dowfrost. Check to see if your coolant shows signs of the dye. If it is not on the floor it must be ending up in the coolant. Check the cool thru hoses and fittings, and around the spindle base and fittings.
    Apr 2014
    9
    If your machine has Dowfrost through the Ball Screws it may be leaking at the bearing blocks. Three seals around the screw in the back of the bearing block is were the coolant enters and exits the screw. If you find the leak just unhook the quick connect tubes and join them together with a union so you don't starve the rest of the system.
    Jan 2012
    12
    If you find the leak is coming from one of the bearing blocks, you may want to look close and see if the grease has been washed out of the bearings, if you catch it soon enough it may be worth re-greasing the bearings. I'm personally a big fan of looping out the bearings blocks as Acrodoc suggested, I've replaced a lot of bearings way too early because of failed seals like this.
    I AM GLAD TO TAKE THIS OPPORTUNITY TO INTRODUCE OURSELVES AS ONE OF THE LEADING SUPPLIERS OF Precision Bearings use for CNC and Machine tool ,AND Radial-Axial bearings WHICH ARE MAKE OF Wafangdian Tianjiu Bearings Technology Co.,Ltd.
    WE ARE IN THIS BUSINESS SINCE LAST FIFTEEN YEARS; IN THIS SPAN OF TIME WE HAVE SUPPLIED PRECISION IN ALMOST ALL THE CONTINENTS OF THE WORLD.
    BESIDES, WE DEVELOP HIGH-PRECISION YRT ROTATED BEARINGS, MACHINE TOOL MAINSHAFT BEARINGS AND MOTOR PRECISION BEARINGS. THE PRECISIONS OF OUR BEARINGS HAVE REACHED LEVELS OF P5, SP, P4 AND UP.
    FEATURED BY HIGH PRECISION, LOW NOISE, HIGH ROTARY SPEED, HIGH QUALITY AND LONG SERVICE LIFE, OUR PRODUCTS SAVE USERS’ COST AND SHORTEN PURCHASE TERM. WIDELY APPLIED TO COMMON MACHINE TOOLS, CNC MACHINE TOOLS, LARGE / MIDDLE MOTORS, PRECISION ROLLING MILLS, ETC., OUR PRODUCTS FILLED THE DOMESTIC BLANKS AND CAN SUBSTITUTE IMPORTED PRODUCTS.
    THIS IS TO INFORM YOU THAT WE HAVE PRECISION BEARINGS AND OTHER GOOD QUALITY BEARINGS AVAILABLE, CAN SUPPLY FOR YOU WITH BEST QUALITY.
    WE HOPE CAN CORPORATION WITH YOUR COMPANY.
    WE CAN SUPPLY OUR BEST PRODUCTS FOR YOU.
    THANK YOU !
    REGARDS!
    Lixingwen(栗星文)
    (Wafangdian Heavy Bearings Researching & Manufacturing Co.,Ltd.)
    Brand:WZFB
    Web: 瓦房店天久轴承科技有限公司(原 瓦房店重型轴承研究制造有限公司)
    Tel: 0411-85366785
    Fax: 0411-85366785
    Mobile:+86-15942617721
    E-mail:[email protected]
    Q Q : 178702120
    Skype: lixingwen1987
    Do our best to give customer best service.
  1. Spindle assembly leaking coolant.
    By l u k e in forum Haas Mills
    Last Post: 03-19-2011, 07:53 PM
  2. VF3 leaking oil out of bottom of spindle
    By kbspeed in forum Haas Mills
    Last Post: 09-24-2009, 11:10 PM
  3. Haas VF7 spindle gearbox leaking
    By Tsugami man in forum Haas Mills
    Last Post: 06-18-2009, 11:21 PM
  4. SL-10 leaking like an old dog?
    By shawncnelson in forum Haas Lathes
    Last Post: 11-05-2008, 09:42 PM
  5. thru spindle coolant leaking
    By GARY DAVIS in forum Fadal
    Last Post: 03-25-2008, 01:28 PM
