587,818 active members*
3,091 visitors online*
Results 1 to 11 of 11
    Aug 2011
    252
    Spindle Start Delay Settings
    My spindle is 24000 rpm and is up to that speed in 10 seconds.
    Question: It is possible to set delay start for RPM in percent?
    I mean 24000 is 100% in 10 seconds, if speed is set at 6000 rpm which is 25% of max speed, the delay start time to be also 25% from 10 seconds? (Like 2.5 seconds.)
    Can I do that with scripting or it has to be done as software implementation?
    Thank you.
    Sep 2018
    14
    Re: Spindle Start Delay Settings
    The VFD is ramping up the spindle RPM while limiting the current not to exceed the spindle maximum current. There is no guarantee that the spindle speed increases linearly in time.
    Also, I would recommend to give 4-5 extra seconds for the VFD/spindle to stabilize the RPM - in the end it is an adaptive process, with the actual RPM "oscillating" around the desired RPM. Do those few seconds matter that much?
    Aug 2011
    252
    Quote Originally Posted by RaraAvis View Post
    Yes, in some circumstances...
    Thanks.
    Aug 2011
    252
    Ok, I've found _spindle_delay_start, now I need to think how to use it.
    Aug 2011
    252
    I found a way but can only use _prog_minspindle or _prog_maxspindle and are not useful anyway when program multiple toolpaths with different spindle speeds.
    So I modified my post processor and job done! I will set in PlanetCNC no delay.
    Edit: PlanetCNC have many useful scripts but the lack of documentation makes them almost impossible to use.
    Mar 2017
    1332
    Or you you could edit M3 script.
    This is where _spindle_delay_start is used.
    Code:
    O<PlanetCNC> if [#<_spindle_delay_start> GT 0]
      G04 P#<_spindle_delay_start>
    O<PlanetCNC> endif
    Aug 2011
    252
    Quote Originally Posted by PlanetCNC View Post
    I knew this. The problem I had was not knowing how to check spindle command speed before execution to set the delay before execution for every spindle command.
    Mar 2017
    1332
    '_spindlespeed' parameter will get you current 'S' value
    Aug 2011
    252
    I knew this to, I don't know what I did yesterday wrong, but today after another quick test it's surprisingly working... (maybe I was tired and made some mistakes)
    Thanks for reply's, otherwise I would have abandoned the attempt.
    OnStart script @ Line: 0
    Start spindle CW
    speed=6000 delay=3
    Stop spindle
    Start spindle CW
    speed=12000 delay=6
    Stop spindle
    Start spindle CW
    speed=24000 delay=12
    Stop spindle
    Start spindle CW
    speed=6000 delay=3
    Stop spindle
    OnEnd script @ Line: 8
    Mar 2017
    1332
    I know documentation can be a lot better but it seems that in this case it was good enough.
    You knew everything was needed to do this thing :-)
    Aug 2011
    252
    Yes, but after searching through manual and scripts to see which does what...
    Hopefully will see documentation complete and will be a lot easier.
    Thank you.
  1. Spindle soft start delay
    By justinj in forum LinuxCNC (formerly EMC2)
    Last Post: 08-23-2017, 04:25 AM
  2. Spindle delay
    By mkc2 in forum Mach Mill
    Last Post: 01-06-2009, 01:56 PM
  3. Pierce delay and plunge rate settings.
    By Fiero Addiction in forum Waterjet General Topics
    Last Post: 07-20-2008, 12:05 AM
  4. HL-2 close chuck, delay, cycle start
    By djr76 in forum Haas Lathes
    Last Post: 03-06-2008, 07:21 PM
  5. Start delay on Thermal Dynamics 151
    By Scratch in forum Waterjet General Topics
    Last Post: 06-01-2006, 05:22 PM
