I managed to get the rack gearing mounted to 1/4" thick strap. I am mounting the gear in this manner so in the event of the gear getting damaged I can simply purchase a new strip of gear, drill it & mount it. I also wanted the rack set out from the table frame to allow the pinion full surface width without fear of any end play causing the end of the pinion to contact the frame rail.
I used hot roll strap for 1 side & cold rolled for the second. I highly recomend the use of cold rolled. It was much easier to get the gear accurately placed, for obvious reasons, the CRS is much more uniform. It wasn't worth the little bit of savings to struggle with the HRS.
