Originally Posted by
cSpampinato
background info:
In our shop, we have a horizontal mill (Mazak H500/50 with M-32 Mazatrol controls) that was bought at an auction a couple of years ago. We haven't messed with it until recently because nobody here knows how to run a Mazak, we all run machines with fanuc controls. We got it hooked up, got rid of some alarms that used to appear at start up, and did some modifications to the machine. We set the machine up for the very first job that we're going to run, set x0 & y0 (to the best of my knowledge), set the z offset for tool 1, and manually typed up a program on the machine.
problem:
Like I already mentioned, we don't know how to operate Mazak controls. I keep pressing Cycle Start and get a couple of alarms. One is when I'm in the program screen (where I typed up the program), I try to run the program and get an alarm that says 'impossible screen cycle start'. So I go to the command screen and try Cycle Start, I get 'execution impossible'. While on the command screen, I look at the upper right corner of the screen where the work # and line # are indicated. Both values are blank. Finally, on the command screen, I select 'wrk no.' and type '1' (the program # I created) and the machine says 'data renewal not allowed'.
Thank you in advance.
