603,864 active members*
5,453 visitors online*
    Feb 2007
    27
    Question Step/Dir Stepper Control
    Hi
    I have three bipolar stepper motors and I would like to control them with CSTEP which uses the parallel port. The options for output are:
    Conrad SMC
    Phase Control
    Pulse Dir.
    Does anyone know of any low cost controllers that support these outputs for bipolar motors?
    Kyle
    :withstupi
    Jun 2004
    463
    Can't make a drive recommendation without knowing the specs for your motors(ie current and voltage).
    Feb 2004
    361
    Probably the easiest controller style to get would be the pulse/dir type, pretty common on ebay, as well as other places, there are also hobby versions that you can build yourself such as alans picstep, or the ones on pminmo's site..
    enjoy..
  1. pic step can it be used with 6 wire stepper motor?
    By oliverthepig in forum CNC Machine Related Electronics
    Last Post: 08-22-2006, 09:54 PM
  2. step motor control
    By Diego in forum CNC Machine Related Electronics
    Last Post: 08-18-2006, 11:37 AM
  3. Step and direction info on M control
    By colin1544 in forum Centroid CNC Control Products
    Last Post: 05-31-2006, 02:00 PM
  4. step and direction control for opto22 servo drive
    By drewgarth in forum Servo Motors / Drives
    Last Post: 05-21-2006, 07:31 PM
