603,890 active members*
3,520 visitors online*
Results 1 to 6 of 6
    Oct 2004
    38
    step in what direction
    I am building a gantry style CNC it is all aluminum with a 36''x24'' work surface the type of work will be wood and aluminum sheet metal and the odd aluminum plate 1/4'' milling work i will have coolant for that aplication
    My question is wat tipe of steper should i spec out
    Voltage , unipolar ,bipolar vextra ,Amperage degrees, and steps this is confusing because there are so many out ther and i want something strong and easy to configure or replace I a good metal worker but the electronics !!!!
    craftech
    Mar 2003
    35494
    Maybe something like these:
    http://www.orientalmotor.co.jp/cgi-b...K&frameSize=85
    Use Geckos, wired bipolar parallel at around 30V.
    If this is in your budget, you'll get quite a bit of power for a very reasonable price. You could probably get away with a little less power, but you can never have too much power either.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2004
    38
    Hey Gerry thanks for the advisse i will look for these type for the project and yes it in the budjet OK and will post the picture and devellopement of the machine
    Thanks again
    Mar 2003
    35494
    If you look at the thread for InventIt 's router, he uses these motors and can get over 300ipm with 1/2-10 5 start acme screws. If I ever finish my first router, I plan on using those motors for my next one.
    Here's the link to InventIt's thread:
    http://www.cnczone.com/forums/showthread.php?t=2249
    Gerry
    Oct 2004
    38
    hey cool pictures what is a 1/2'' x10 5 start 2 pich meen or is this just a threaded rod
    Mar 2003
    35494
    Instead of a single thread wrapping around the screw 10 times per inch, there are 5 seperate threads that wrap 2 times per inch. So you still have 10 threads per inch, but you only have to turn the screw 2 times to move one inch. Screw with multiple starts are more efficient than single start screws, sort of midway between single start and ballscrews.
    Gerry
  1. A Axis and Step and Direction Spindle Setup
    By mklb in forum Mach Software (ArtSoft software)
    Last Post: 11-27-2009, 02:19 PM
  2. Beta Testers for QMill/CNC discussion
    By cncadmin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-25-2005, 07:33 PM
  3. Dirction / Step lines!
    By bigal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2005, 08:51 PM
  4. Step and direction software
    By bgolash in forum Gecko Drives
    Last Post: 12-04-2004, 07:29 AM
  5. Step and direction source
    By pauls in forum Gecko Drives
    Last Post: 09-03-2004, 01:19 PM
