603,365 active members*
3,028 visitors online*
    Dec 2010
    Stepper Driver Alarm light
    Hi one of my stepper drivers has stopped working , there is two lights a red and a green . Both of them are on . Which is not supposed to be , the 2 others drivers only have the green light on. It is not due to overheating since it goes on right when i power it up after siting for a day. Anybody would have a solution ??
    Thank you
    May 2007
    715
    I had the same issue with my Gecko 203V driver and it turned out that a bad batch of plugs had caused a loose connection and actualy damaged the board.
    I sent it back and they replaced the driver.
    What type of stepper drive do you have?
    Dec 2010
    It is a chinesse Stepper Motor Driver SD-2H086MB:Stepper Motor Driver SD-2H086MB wholesaler
    The problem did start when it had a loose connection. Since then the light never went off . Do you think they is some sort of a reset ??
    Thank you
  1. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  2. Mitsubishi CNC on lathe: alarm light flickers while threading
    By HuFlungDung in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-11-2009, 10:19 PM
  3. Replies: 3
    Last Post: 06-18-2009, 09:13 PM
  4. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
    By huios in forum Stepper Motors / Drives
    Last Post: 08-27-2006, 02:43 PM
  5. ATC alarm and Dry run light * Help *
    By Chip Maker in forum Fanuc
    Last Post: 05-14-2006, 12:41 AM
