603,893 active members*
2,818 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > stepper setup, Electrical noise ?
Results 1 to 4 of 4
    Oct 2005
    375
    Hello guys,
    Do you know off the setup off a nema 34brush servo next to
    a nema 23 stepper,
    (about 3 inch distance)
    will create some sort off electrical noise, would/could it be possible to shield this setup in some sort off way?
    Some advice will be nice !
    regards,
    Roy.
    No effect on each other.
    Mariss
    Feb 2004
    466
    Imho, if you shield the encoder cabling of the servo and if the stepper motor cables are in twisted pairs each phase, there should not be an issue, maybe keep the stepper and servo cables separate as well.
    Konstantin.
    Oct 2005
    375
    Quote Originally Posted by Mariss Freimanis View Post
    Mariss
    nice to hear, it`s good for my design.
    Another question in relation to the one above then;
    If i use the mcg ID33003 with a gecko g320 at 75VDC and, max 15A peak for spindle control for the endmill, the servo will turn max.3000 rpm (geared up to 10000rpm)
    could the servo turn 3000 rpm for lets say runs off 1hour, or will the brushes die premature. ( for a hobbymill milling alu small diameter)
    Kind regards,
    Roy b.
  1. spindle electrical noise
    By balsaman in forum CNC Machine Related Electronics
    Last Post: 06-02-2013, 12:01 AM
  2. RF noise causing stepper chatter
    By PsyKotyk in forum CNC Machine Related Electronics
    Last Post: 08-09-2006, 02:42 AM
  3. Preferred Stepper Driver Electrical Interface
    By JeremyLee in forum Polls
    Last Post: 02-26-2006, 10:08 PM
  4. Electrical Motor Noise Sherline Mill
    By JohnAn in forum DNC Problems and Solutions
    Last Post: 01-03-2006, 03:33 PM
  5. Electrical noise.
    By MrBean in forum CNC Machine Related Electronics
    Last Post: 01-14-2005, 01:25 AM
