Originally Posted by
ger21
What microstep setting are you using? 2000 steps/inch would be for full step. 1/2 step would be 4000, 1/4 step 8000, 1/8 step 16000.
Someone else reported problems last week with the axis calibration. I'd recommend not using it if it's not working correctly. Perhaps it's changing the steps/unit, but they're not displaying properly?? Not sure, but when you change the steps/unit, you need to re-tune the motors. That might be the problem. Try entering the correct number in the motor tuning screen, then save, close Mach, restart, retune, close mach, restart. See if that works.
