603,323 active members*
4,181 visitors online*
Results 1 to 9 of 9
    Sep 2011
    94
    Stipple art program
    Hello I found a need program here StippleGen: Weighted Voronoi stippling and TSP paths in Processing | Evil Mad Scientist Laboratories
    And am able to make some really neat photos by letting my machine run out all night, however I am unable to do anything with what I make.
    It is able to export an svg file but when I open it in inkscape the export or save as buttons will not appear, and the program generally freezes after a few moments.
    After several hours on the internet I cannot find a program or method anywhere to resolve this.
    My hope is to vcarve the dots, stain it and then sand the top down.
    May 2004
    4519
    Sounds like you are running into a problem with available computer memory due to the large file size required for this type of graphic and resulting calculations needed to generate the tool paths. Change resolution or switch to a computer with much more memory.
    Mar 2003
    35494
    Try Halftoner.
    CNC Software
    or dxf Halftone
    Syvajar3
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2011
    94
    Thanks for the advice, I lowered the number of dots to about a 1/4 as before and it works now I have attached the dxf if anyone want to give it a try, know that you need to let the program run for some time before you get convincing results.
    P.S for anyone else trying this my rig has 3.3 gigs ram so you may need to run it at a lower amount of dots.
    Attached Thumbnails Attached Thumbnails Self-Portrait-in-Old-Age,-Leonardo-da-Vinci,-1512.jpg
    Attached Files Attached Files
    May 2004
    4519
    Glad you got it worked out. Your DXF file opens with zero entities showing in my software. Might want to look at your output format.
    Sep 2011
    94
    Ya sorry about that Ive tried re saving using the different options for dxf output but I keep getting empty 5 kilobyte files anyone have any advice?
    Sep 2011
    94
    I am able to export from inkscape as a jpeg or pdf however these show circles and not dots.
    May 2004
    4519
    Do you need to "select all" before outputting? What other file type option do you have? IGS maybe? STL?
    Sep 2011
    94
    Tried Crtl A and tried select all from the menu no luck, I dont think inscape can output anything else that might work. Even a high res bitmap in not accurate
  1. Mazatrol Program into a G Code Program
    By fuzzman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-25-2012, 04:27 PM
  2. Replies: 0
    Last Post: 12-27-2010, 09:55 AM
  3. Replies: 12
    Last Post: 03-15-2010, 02:19 AM
  4. Program Restart in mid program?
    By Donkey Hotey in forum Haas Lathes
    Last Post: 03-18-2008, 08:19 PM
  5. Replies: 11
    Last Post: 10-09-2005, 05:45 AM
