603,893 active members*
3,264 visitors online*
Results 1 to 4 of 4
    Dec 2009
    35
    Stopping Mach3 machining the table
    I've been reading up on how to limit the Z axis, so that Mach3 does not cut into the table.
    I'm now thoroughly confused between the uses of the term "limit". I understand hard and soft limits, and that they tend to be implemented to shut the machine down when reached.
    I thought that Mach3 offered a facility where you could specify a cut-off point in the Z axis, so that regardless of GCode instructions, the tool would not cut any lower than this set point. More importantly the machine would finish the cut, rather than shut down if this limit was reached.
    Is this the case, or do I have it wrong?
    Steve
    Mar 2003
    35494
    Possible the Z Inhibit? I don't know how it works, though.
    One thing you might want to do is to check the program limits when you load your g-code. The -Z limit DRO will show how deep the cuts will go.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2009
    594
    A good idea is to set your Z zero 1" higher and cut air before running the program with stock. Then you could verify that the cutter doesn't go too low.
    Jul 2011
    Hola estoy buscando para bajar el programa de una frezadora de mach 3, que se me borro la memoria de la maquina y perdi todo, Saludos
  1. Using mill table manually,, mach3 DRO readout
    By TheDude in forum Hobbycnc (Products)
    Last Post: 12-20-2018, 02:56 PM
  2. BF20 Machining underside of X table
    By bladehunter in forum Benchtop Machines
    Last Post: 11-30-2009, 11:26 AM
  3. Trouble machining solid with BCC 21 & Mach3
    By hecirp in forum BobCad-Cam
    Last Post: 11-07-2008, 01:33 AM
  4. Mach3, G100 and an XY table.
    By Golden1ce in forum Machines running Mach Software
    Last Post: 05-27-2008, 03:34 PM
  5. Anyone running Mach3 with a DynaCNC table top?
    By CrashMasterKev in forum Machines running Mach Software
    Last Post: 11-22-2006, 03:36 AM
