for some time I have been thinking of my own cnc-machine. and while thinking and discussing with a frend and theacher we came up with a idea.
Instead of used standart bearing and rail, whe want to construct a cnc machine with is floting on air or oil.
the priciple is simple you take two plates. one is the tabel witch moves, the other is a groundplate. in the tabel you drill a lot of tiny holes (0,1-0,5mm) en trouch those holes you pump air or oil. so the oil or air creates a film between the table and groundplate. so what you get is a table with little friction, and it can withstand a lot of force, becease It cant bent becease it is supported at al the surface.
please give me a reaction what you are thinking of this idea, or maybe there are already cnc machines build in this way....
Gr. Maarten
