603,413 active members*
3,032 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Surfcam post with tool description
    Feb 2010
    5
    Hi every one, surfcam has a post for a haas mill with tool description, does any one know of post for haas lathe with tool description or how to make one of my own. They work so well when you pull them up on the machine later and you have no setup sheet. Thanks Jerry
    Nov 2009
    9
    I know with the lathe post on surfcam, much like the mill post, you can add descriptions in the tool path menu, my suggestion would be to do that. Although i do believe there is a setting in the S-post for surfcam that will let you enable that. im not for sure on that though.
  1. SurfCam Post -repeat tool header info
    By MMTechi in forum Surfcam
    Last Post: 10-17-2015, 04:32 PM
  2. Example of Live Tool Engraving w/ Surfcam
    By bdyenter in forum Surfcam
    Last Post: 06-28-2012, 03:31 AM
  3. Rams tool description
    By rossrods in forum Jewelry Design Software
    Last Post: 03-12-2008, 10:12 PM
  4. Surfcam post for g71
    By villiersterrace in forum Haas Mills
    Last Post: 08-03-2006, 12:44 AM
