603,319 active members*
2,647 visitors online*
Results 1 to 6 of 6
Hybrid View
    Aug 2004
    244
    SV500 servo drives
    I am considering buying 3 sv 500's for my router project. I picked up 3 Electro craft E543 with 1024 line encoders. Any one have this combo, if so how well does it work for you? I am also interested if you have a different set up with these drivers. Are they easy to tune? Would you recomend them? The price is great if they work well or would I be better off with holding out and buying gecko's. Thanks
    Feb 2004
    2337
    Could you please post a link to the site so that we can see the "great price" etc.
    Being outside the square !!!
    Aug 2004
    244
    They do not have the prices listed right now but i rember that if you but 3 they were around $65 each or around $85 if single here is a link http://www.cadcamcadcam.com/index.as...ATS&Category=3
    Jun 2003
    451
    Hi eman5oh,
    the driver cards look ok but are only rated to 30 volts, from the information I have gathered about the E543 motors (I have some and intend using them on my project) they are rated at 60 volts which means the SV 500 cards will work but you wont be able to acheive maximum torque or rpm from your motors. For me the jury is still out on which cards to use but I am leaning toward the Rutex r990h.
    Cheers
    Splint
    Aug 2004
    244
    I tested the servos in the lab and at 30 volts I should be able to get 200 IPM on my setup and they feel to have way more torqe than the steppers that they will replace. The sv500 would be maxxed out in this aplication but would provide way better preformace than the steppers i have now. I can buy the sv500 now but will have to wait a few months to buy geckos or rutex cards.
    Feb 2004
    4
    hi, i'm about to buy some sv500's to put up a cheap CNC router, anyone tried those drivers already?
    my servo's will probably be 12V 3 or 4amps, do you know a cheaper servo driver than the sv500 ($65 each when buying 3 of em)?
    regards, Max.
  1. Can Gecko's servo drives be used with steppers?
    By bgriggs in forum Gecko Drives
    Last Post: 05-26-2005, 06:39 PM
  2. What servo drives use resolver inputs?
    By murphy625 in forum Servo Motors / Drives
    Last Post: 03-15-2005, 07:28 PM
  3. Control Technology Corp. Servo drives
    By tpworks in forum CNC Machine Related Electronics
    Last Post: 04-18-2004, 02:59 AM
  4. steppers or servo drives
    By mmjpotter in forum Gecko Drives
    Last Post: 03-30-2004, 09:56 PM
  5. Servo motors, Drives
    By Wolfe in forum CNC Machine Related Electronics
    Last Post: 11-16-2003, 08:47 PM
