587,240 active members*
3,682 visitors online*
Results 1 to 15 of 15
    Aug 2009
    44
    SYNTEC 900ME parameters password
    Hello everyone.
    I have an old mill with a Syntec 900ME controller and i need to alter some machine parameters.
    The problem is that when i want to change anything it ask for a password, which i don't know.
    Is there any default password or any other way to reset the password ?
    I read somewhere for a 520 password but it does not work on my machine.
    Any help would be appreciated.
    Sep 2009
    99
    Re: SYNTEC 900ME parameters password
    You could contact Syntec directly for this (I could DM you their contact details if you would like)
    I have visited them in Taiwan- they're a good and helpful company. I have 5 machines with their controllers in my factory at the moment.
    Best regards
    Jaideep
    Aug 2009
    44
    Yes please if you could send me the contact i would be greatfull..
    Feb 2007
    4
    Hi Jaideep,
    I need password for Syntec 6MB as well,
    could you please send me the contact also.
    Thanks.
    Apr 2021
    10
    Quote Originally Posted by ounsiam View Post
    Hi Jaideep,
    Thanks.
    Did you ever figure out password problem. I am in the same boat but thinking on reloading but I would much rather hack it
    Brian
    Apr 2021
    10
    Quote Originally Posted by geast1967 View Post
    Did you ever figure it out I am in same boat
    Sep 2009
    99
    Dear Brian,
    My machines password is 520 from what i recollect. If you enable your direct messages I will send you the contact details (I do not wish to post these on an open forum as the personnel at Syntec would get spammed otherwise)
    Best regards
    Jaideep
    tengo el mismo problema con mi Syntec 20TA se descargaron las baterias y se borraron las referencias, quisiera saber si hay algun procedimiento especial ya que me pide una contraseña intente con las 520 y 521 pero no funcionan, gracias.
    Aug 2009
    44
    The default password is 520, if it is not then you will need to consult to your machine maker/seller.
    geast1967 tendras algun procedimiento para volver a guardar las referencias, mis servos tienen encoder absolutos.
    Aug 2009
    44
    You better contact direct to Syntec to that email,[email protected].
    Regards.
    Hello everyone.
    Just looking forum about Syntec and it seems that your system configuration is same as mine.
    4 axis with 2 CF Card Installed (DOS).
    I wonder why suddenly it asking for password, and I can't find the password anywhere.
    The bad news is I haven't backup the original CF Card that located inside.
    It asking for password for Check No. 3318
    Can you help me with my issue?
    Aug 2009
    44
    You have to contact the machine builder, for the password.
    Aug 2006
    6
    Try 521
    Jul 2010
    46
    Dear geast1967,
    Does your machine have a CF card inside the controller? (on the advantech's PCA6773 motherboard?)
    Best regards
    Michael
  1. Syntec VMC 1060 password
    By mandis in forum Chinese Machines
    Last Post: 07-14-2023, 04:31 PM
  2. Replies: 0
    Last Post: 02-17-2015, 11:50 PM
