587,157 active members*
3,229 visitors online*
Results 1 to 5 of 5
    Apr 2008
    3
    taper thread cutting
    hi all
    this is my first posting on this site and hope someone can help.
    i operate a mazak vertical centre nexus 510c with mazatrol 640m controls
    my problem is that i need to machine bspt and npt internal threads.using a single point tool. can anyone help with a sample program for this or is there a program i can down load to work it out.
    hope you can help
    bill
    Jul 2003
    1220
    I know nothing about a mazatrol controller but I could send you a g-code file of a tapered spiral. If interested what threads and cutter diameter?
    Apr 2008
    3
    kiwi
    thanks for offer.will get back on sizes etc
    bill
    Apr 2008
    3
    the thread size is 1.5 npt using 27.oo mm dia cutter
    Jul 2003
    1220
    cncmc
    File attached. See note at head of file.
    Suggest you do trial run and advise if needing modified.
    Attached Files Attached Files
  1. cutting a taper on titanium rod
    By marty7001 in forum MetalWork Discussion
    Last Post: 05-21-2014, 02:06 AM
  2. Need thread cutting help
    By Larry Myers in forum Sharp CNC
    Last Post: 03-08-2008, 06:26 PM
  3. Need thread cutting help
    By Larry Myers in forum G-Code Programing
    Last Post: 03-06-2008, 10:38 PM
  4. Replies: 3
    Last Post: 01-08-2008, 06:13 PM
  5. taper thread
    By gcrandall in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-17-2006, 04:13 PM
