603,385 active members*
2,535 visitors online*
Results 1 to 4 of 4
    Oct 2018
    6
    Techno Davinci
    Gentlemen, Just joined today, mainly because I have a line on a Techno DaVinci CNC machine. I am being told it currently doesn't work. Trying to get the current owners intent and a substancially better description of what "It doesn't work" means. I have several questions. I am new to CNC, but not new to electronics and computers.
    I have attached pictures of the machine. It appears to have servo motors. I have also reached out to Techno Support and this machine is fully supported.
    I suspect the reason it currently doesn't work is due to the controller. My questions are
    What would need to be replaced to run this on Mach 3? I guess being new I need this spelled out
    Does the Gecko G540 work with servos? I don't think so.
    Is it worth considering a g540 and swapping out the servos for steppers?
    Sep 2012
    230
    Re: Techno Davinci
    Hello,
    Running mach3 on the machine with geckos would mean a gut job on the electronics and motors.
    In my opinion, replacing servos with steppers is a huge step down in quality and reliability
    If you're the person I spoke to by email yesterday, I think the odds are good that it will be simple to get the machine running as it was intended, let's give that a shot first and see how it goes. Could be as simple as a fuse.
    Eric Feldman - Design Engineer, Programmer
    Armor CNC - http://www.armorcnc.com Support hours: 7am thru 10pm EST, 7 days a week
    Apr 2004
    5948
    Re: Techno Davinci
    Geckodrive does make drives for servos - the G320 will run DC servos from step/direction inputs. But Eric's right - that would be a last resort. Troubleshooting the existing setup would be the first thing to do. If you haven't bought it yet, the price should reflect its non-functional condition = don't pay more than the working components are worth.
    Andrew Werby
    Website
    Oct 2018
    6
    Re: Techno Davinci
    All running and working thanks to Erik.
  1. johnohara's Techno-Isel DaVinci
    By johnohara in forum Techno CNC
    Last Post: 01-26-2021, 01:37 PM
  2. Techno-Isel Davinci upgrade help
    By Ferny in forum Controller & Computer Solutions
    Last Post: 08-05-2020, 12:25 PM
  3. Help mounting motor on Techno DaVinci
    By AlexAnnapolis in forum Techno CNC
    Last Post: 03-20-2017, 01:05 AM
  4. techno davinci book or pdf
    By grebber in forum Techno CNC
    Last Post: 04-27-2015, 01:01 AM
