Still looking for an alternative to fitting a THC interface card inside the box. Why? Here in Europe - it's a health and safety nightmare and is certain to void the warranty of the plasma unit. How do you Stateside guys get round this?
Anyway - I'm thinking of an attachment containing a simple potential divider - two resisters - nothing else - attached between the torch tip and the torch mounting bracket to feed out the scaled down voltage. All ancilliary circuitry like TVS and rectification, conditioning etc. can then be placed inside or alongside the THC proper. This could even work with available THCs like THC300s and their ilk simply by tapping in after their onboard potential dividers (a feature I think is already provided on my THC300 - 2 jumpers marked "external divider"). Thoughts?
The current transformers for good arc detection can presumably go round the external work clamp lead rather than inside the box. Of course an electro-mechanical moustrap will have to be used for torch triggering to replace tapping into the torch switch contacts inside the box - again - thoughts?
