587,197 active members*
2,911 visitors online*
Page 1 of 2 12
Results 1 to 20 of 28
    Smile Thunterman's jgro iteration
    This is my first post after reading / learning over the past year or so. I had built a little demo two axis machine to learn the concepts of CNC. After that I was ready to jump in and build a working model. I chose the jgro design. This is a very nice design to begin with as the construction is not very complicated for a novice to intermediate woodworker. Jgro, thanks for providing the plans!
    Although this is a good design, aligning this thing is a "bear". I don't think I ever will be able to get it to where I want it to be. There is just too much flex in the long Y axis pipes to get to align properly. I'll live with what I have for now as I only will be cutting wood and I don't need to have “.001” accuracy.
    I started work on the machine in April of last year (2005). After many trips to the local hardware stores and purchases on eBay and other sites, I have a working CNC router today!
    Here are some specifics of the machine. I use 3/8" 16tpi alltread for the leadscrews because the end bearings I had would accept a 3/8" shaft. I will upgrade to 1/2" acme or maybe ballscrews in the future. The adjustment blocks are made out of 3/4" UHMW plastic as are the AB nuts. I used the trick of freezing the AB nuts before taping them. They turn without almost any effort.
    The controller is a 3 axis HobbyCNC kit. Thanks to Dave R. from HobbyCNC! This kit goes together very easily as long as you take your time and have some decent soldering skills. (My background is electronics/software). I'm running three Vexta 118oz-in 2 phase 1.5amp motors; yes they are a little underpowered for this machine, so I just run at a lower ipm rate. I built a 33.5vdc unregulated power supply to power the machine.
    For a spindle, I will be mounting a 400W 24000rpm "trim router".
    I built a mobile cart/stand for the machine so I can move it around my garage or outside when the weather is cooperating (I live in Minnesota, USA - "You betcha!").
    I have wired home and limit switches on all three axes. At the present I am having some noise/crosstalk issues on the long limit switch wires. I will need to wire the shields on wires to ground to resolve this issue. I hope that will correct the problem.
    I have been using a "demo" copy of Mach3 and also TurboCNC. I like them both. I'm leaning toward MACH3 as I like the interface that this software provides. The price is reasonable for this software and I will probably end up purchasing this. I also have a demo copy of VCarve. Very nice software, but the price is giving me second thoughts as I may develop my own carving software instead using the Delphi programming language.
    What speed do I run at? Well, I've tested various micostepping rates and ipm's
    and presently running at 1/4 step rate and about 40ipm with maybe a slight bit of resonance. I will have to do some more testing to determine the best rate.
    Don't even ask me what this thing has cost me so far! I'm not sure I want to know, even though I have kept all my receipts. This a hobby, don't ya know!
    OK, this is a long winded post. I know you guys/gals like pictures, so I have a web site setup that has quite a few pictures and a video of the "First movement" You can read/view it here: http://cnc.hobby-site.com/cnc.htm
    JUST DO IT!
    Thunterman
    Oct 2005
    1238
    Thunterman
    That is a great record of your project shown on the web site you created.
    Thanks for sharing the info & the link to it.
    This is part of why CNC Zone is such a wonderful place!
    WT
    Jul 2003
    276
    I tried to view the video twice... gets to 96-97% then stops
    weldtutor, thanks for the comment! I'll keep adding pics and videos until I run out of disk space (4.3G)!
    randy, I tryed downloading the video from my work PC and allthough it's slow I was successful. Try saving the file first before attempting to open it. My web server is running on a old 200mhz PC that is loaded with Win98 and sits in my furance room! If still unsuccessful, I'll try to resize the video or use a different format(quicktime)
    Feb 2005
    578
    Thunterman, such drama on your video. Very professional.
    Good job. You have been very quiet and very busy. Mark of a true Minnesotan.
    Flex and alignment problems in the JGRO is part of the learning experience. Your prototype long pipe side rail support looks promising. Maybe there is a way to make the pipe holder thingies individually adjustable.
    Have you tried a .1uf cap across the limit switches to reduce noise?
    3/8” 12 Acme would give you a cheap speed upgrade without changing your bearings. (If you care).
    Steve
    Jul 2005
    253
    Thunterman
    Your machine is looking good. I finished my about 6 months ago and have been down some of the same roads you have. I used ½ 10 acme screws on mine and have been happy with the speed. But I’m running 276oz steppers, which I think might be a good upgrade for you in the future. As for the software end of things I tried just about every demo under the sun. After many hours I had settled on Mach2/3 for heart of things and then Sheetcam and Meshcam. That way I could cover the 2.5D and any 3D work. Then I stumbled on a demo copy of Vcarve. When I saw the price I had my doubts. But I after beating up the demo and about 50 emails to their support guys (who are great by the way) I took a chance and bought a copy and I couldn’t be more then happy. I’m not sure what you plan on using your machine for but if it’s signs, carvings and 2.5D work, etc you can’t beat Vcarve.
    Two threads you should check out if you haven’t already are:
    http://www.cnczone.com/forums/showthread.php?t=15995
    http://www.cnczone.com/forums/showthread.php?t=12332
    Also being a fellow programmer I had ideas of writing something of my own. But then the thought accrued to me that I can spend all that time writing something and working out all the bugs or I can start using my machine now.
    Well good luck with your build, and no I don’t work for Vertric. I just think bang for the buck it’s pretty good stuff. There’s my two cents, use them as you see fit.
    Take it easy.
    Jay (www.cncjay.com)
    steve, creating videos, just another one of my too many hobbies! The wife says I have some compulsive tendencies! I had fun creating that video. The prototype side rail support that I had created also had flex in it since I used MDF to construct it, so I decided not to use it as it didn't provide much support anyways. I'll live with the rail flex for now as I'm planning to build another machine. I'll try the .1uf cap trick and see if that will correct the noise issue on the limit switch wires. Thanks for the tip. Using 3/8 acme is also a good choice for me. I'll give that a try this spring.
    Jay the current motors I'm using were fairly cheap to purchase. This is one area that I will upgrade in the near term. I'll be mounting a trim router for a spindle this weekend and we'll see if these motors can handle the added weight and speed.
    On the software side, MACH3 will be my choice for the controlling software. Sheetcam and Meshcam will provide all my needs for cutting 2.5 and 3d. Vcarve is a great piece of software, very nice user interface, well layed out and intuitive, however the price may be a little high for my "hobby work". Yes, I had viewed those threads on vcarve, very nice work. If I can generate some revenue from this hobby, then maybe I'll purchase the software.
    Jul 2003
    276
    must just be me! even downloading it it gets to 96% then just stops downloading with 6 seconds to go.
    Nov 2003
    634
    thunterman, Good job. I downloaded the video and it started playing at about 50% download and didn't have a problem.
    Somewhere on the web, I remember a site with a CNC controlled long arm quilter. That might be a good project for you. It seemed to complicated to me because you had to worry about skew in the material and other fabric related problems.
    Anyways, good job. I'm in Rochester, about an hour and 1/2 from the twin cities.
    randy ,I don't think my little web server is handling all the added traffic well, in fact it crashed today. I may have to upgrade to a faster machine. This weekend I'll add a second video that will be a smaller download, so hopefully that'll work for you. I probably will also have some more pics.
    buscht
    , well at least some are able to download the video. I think building a CNC quilter would be a little out of my league. I didn't even know what CNC was a year ago! I need to work with the jrgo for awhile to learn all the software (g & m codes, cad/cam etc....). I think this will take quite awhile. Good to see there are others in MN that are on this forum...
    Jul 2003
    276
    I have a sister in law that has a manual quilter, uses aluminum tubes and uhmw slides to move the sewing machine back and forth and roll the material manually from 1 spool to another... alway thought of cnc'ing it.
    I will get some more info on it if anyone is interested... I know she bought in from a quilting shop in Iowa a couple of years ago
    Mar 2003
    35538
    Quote Originally Posted by thunterman
    If your using Mach3, try increasing the "Input Debounce" in the Logic settings screen, to maybe 2000, or even 5000 and see if that helps.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    randy, my wife did see that quilting machine at a quilting show up in Duluth, MN. Funny, she mentioned that I should build one and CNC it! They do take up quite bit of floor space however. If you know of a web site I'd be interested though.
    ger21, yes I'm using a demo copy of MACH3. I haven't read the entire PDF file for MACH3 yet, (still learning) so I didn't know about the debounce settings. I'll try that before I try the hardware fix. Thanks for the tip! I am becoming a little bit overwhelmed with all the help and support from this forum. Truly amazing! Thanks to all!
    Apr 2004
    90
    thunterman,
    I really like the enclosures you have for the power supply and drive board. Where did those come from?
    Brian
    Feb 2005
    578
    Thunterman,
    Looking back at your thread, it seems like you have not decided on a CAD CAM solution. I hear ya, this is where a lot of the money goes. If you would like some more free G-code to just drive the machine around, you might want to try cutting (drawing) some spirographs. Here is a link to a tool to produce them and other designs. Just download the file, unzip it, and run it.
    http://www.cnczone.com/forums/showpo...&postcount=117
    Here is a link on how it was developed.
    http://www.cnczone.com/forums/showth...ght=spirograph
    I grew up in Northfield, half way between Rochester and Minneapolis. I had sense enough to leave.
    Steve
    Brian, the enclosure for the power supply I built from scratch using sheet metal and aluminum angle from the local Home Depot. It is mostly pop riveted together with some screws for the top and bottom. I cut the sheet metal using a tin shears and cut the holes for the various switches, fuses and light with a "nibbler". The enclosure for the controller was purchased from "Mouser" electronics. It is the enclosure recommended by the HobbyCNC site. The brand is "Pactec" and the model is "DM-4". I couldn't fit the controller and power supply in the Pactec case as the capacitor I had was way too big to fit in the case. I had bought the case before I had the cap.
    Looking back at your thread, it seems like you have not decided on a CAD CAM solution. I hear ya; this is where a lot of the money goes. If you would like some more free G-code to just drive the machine around, you might want to try cutting (drawing) some spirographs. Here is a link to a tool to produce them and other designs. Just download the file, unzip it, and run it.
    Steve, cad/cam will be an issue as I have very little experience with these. The learning curve appears to be very steep! I have a demo copy of BOBCAD and also have copy of Alibre Express. I need to view the tutorials on Alibre. BOBCad has very little documentation with their product. This seems to be a "sore" point with product. My wife has a copy of Corel Draw Version 12. I'm using that for now as I can export to a .dxf file with that tool. We're both learning Corel Draw and the concept of vector graphics vs. bitmaps. My main use will be to trace a topo map in 8 bit grayscale, convert to vector graphics, and build the tool path and attempt to cut 2.5g.
    I'll take a look at the suggested spirographs links and play with those. Thanks for the tip!
    What! You don't like snow and cold? Me either. Wife and I are looking as Ashville, NC for a retirement area.
    Thunterman
  17. #17
    Nov 2003
    634
    Sorry to intrude on your thread, but here's the link for the CNC long arm quilter.
    http://www.statlerstitcher.com/
    I think that there are more types out there, but this site is very informative.
  18. #18
    http://www.cnczone.com/forums/showp...7&postcount=117
    http://www.cnczone.com/forums/showt...ight=spirograph
    Mounted a 400W 28000rpm laminate (trim) Router this weekend on the jrgo. Downloaded the spirograph program suggested by spalm. Cut out the Flower2.spr example as the "First cut" on the jrgo. I've attached a pic of the sample cutting. I can see I'm going to need a "dust collection" system on this thing! Cough!
    Working on a video of the cutting that I'll post in a few days...
    Thunterman
  19. #19
    Added a "First Cut" video and some additional pics to my web site. Used the "PhotoVCarve" demo for the cutting. Very nice software! Was using a 90degree V cutter on MDF. The cutting wasn't that great. Probably because of a small flat tip on the cutter and the use of MDF for cutting material. Need to purchase some decent V bits and end mills. Any sugesstions for a source on the net? Took about 1 1/2 hours to cut this image! 10ipm feed rate.
    thunterman
    JUST DO IT
  20. #20
    Feb 2005
    578
    Mr Thunter:
    I think I know what you mean about the flat spot you describe on the bottom of your V bit. For some reason it seems like some manufactures think this is OK. It drives me crazy as it never shows up in their drawings. It seems to be more prevalent in smaller bits. 1/4” (not shank) have it while 1/2” do not. I personally like Freud bits. There are tons of places that sell bits. I have had good luck with RouterBitWorld as they only charge $1 shipping for every order. Here is a link to a V bit that works for me.
    http://routerbitworld.com/product_in...ducts_id/23866
    Steve
Page 1 of 2 12
