587,888 active members*
3,256 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Tips on drawing Ratchet/Pawl?
    Jan 2010
    294
    Messed with this a couple times with no luck, I'm curious how I should go about drawing a ratchet "sprocket". Is there some type of radial array tool Or similar I can be using to accomplish this?
    Just looking to make a 2 to 3" O.D sprocket with angled/swept teeth to catch a pawl.
    Thansk for any help,
    Ben W
    www.steelplinkers.com
    Feb 2009
    2143
    Use "Utilities - Rotate". Turn on the "Copy" function for the number of copies you need, define what number of degrees between each set of your copies (360/# of copies) - around the Z axis if it is drawn on the XY plane.
    So, if making a 5 position sprocket with the geometry spun around the origin, choose the geometry you want to copy radially (with Right-Click OK), choose "Copy" and enter 5 parts, enter the origin as 0,0,0, enter 72 degrees around the Z axis (0 degrees around the X and Y axes, click OK.
  1. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
  2. Ratchet/R-F stop micrometer
    By fpworks in forum Calibration / Measurement
    Last Post: 02-04-2007, 05:54 PM
  3. anybody compare HT finecut tips to TD 1Torch tips for dross?
    By Knut in forum Waterjet General Topics
    Last Post: 09-29-2006, 07:17 PM
  4. Ratchet or Ratchet-Friction stop micrometer
    By fpworks in forum MetalWork Discussion
    Last Post: 08-22-2006, 04:47 PM
  5. Drafts: Tips for vendors and tips for RFQ writers...
    By InspirationTool in forum Employment Opportunity
    Last Post: 12-21-2005, 03:44 AM
