603,976 active members*
2,756 visitors online*
Results 1 to 7 of 7
    Jul 2007
    21
    TOO MANY AXES COMMANDED
    Hi every one . My machine has a Fanuc 6m model b control . My machine moves three axes simultaneously. But something happens and now it moves only tow axes simultaneously. Please help me someone to fix the problem
    Thanks a lot
    Feb 2007
    664
    try power down the machine
    Aug 2011
    2517
    a bit more detail might help. something happens? exactly what happened?
    Jul 2007
    21
    Thanks for your interest
    Sometime in the past, something i settings in Graphic parameter. After a few days I realized that if I give a command G00 XYZ show me a message Alarm 015. While the commands G00 XY OR G00 XZ OR G00 YZ running normally. The same happens with the G01. For several months, I worked the machine in this way, now I need to do a tread milling , so I need all three axes.
    Feb 2011
    640
    did someone change parameter 3.2 by chance?
    Jul 2007
    21
    Maybe but what can i do now and what is the parameter it can make the machine to be controled 2 or 3 axes simultaneously, to check .
    Parameter 001 bit 0 "3 AXES SIMULTANEOUSLY"
    Parameter 001 bit 2 "3 AXIS SIMULTANEOUS MOVE"
    put both bits, 0 and bit 2, to 1
  1. Turret will not index as per commanded.
    By blakemachine in forum Fanuc
    Last Post: 01-09-2013, 10:07 PM
  2. Replies: 9
    Last Post: 06-21-2012, 05:47 PM
  3. 197 C-AXIS COMMANDED IN SPINDLE MODE
    By padobranac in forum Fanuc
    Last Post: 05-04-2010, 11:45 AM
  4. unusable G code commanded
    By teamjnz in forum Fanuc
    Last Post: 08-31-2009, 01:28 PM
  5. parser: commanded z axis move to far possitive
    By tonymann in forum Bridgeport / Hardinge Mills
    Last Post: 11-10-2007, 06:05 AM
