I have a 5'x10' CNCRP machine with their spindle. I am getting some significant tool chatter when the machine transitions from y axis travel to x axis travel. I am running a .25" compression bit at 200 ipm. the chatter is really bad at the top left and bottom right corners. You can actually see the machine shake when it makes that transition. I am at my wits end. I slowed down to 90 ipm and it helped but surely I thought I should be able to run that machine faster than that. Any ideas?
Scott
