603,795 active members*
3,008 visitors online*
Results 1 to 7 of 7
    Mar 2008
    5
    tool nose compensation problem
    Hello!
    I have a problem with a small program part, whre I use tool nose radius compensation. the tool simply does not want to go where I want
    Here is the program part:
    T0707
    G50S1500
    G96S180M3
    G0X43.Z3.
    G1G41X42.6Z3.F.1M8
    G1Z0. <-----------------on the graph here it goes in Z-.234
    G1X42.Z-.3
    G1Z-2. <---------------here it goes right (Z-2.)
    G1X27.6 <------here x is wrong with the same value as z before
    G1X27.Z-2.3 <-------both are wrong, same value as before
    G1Z-13. here it goes in z-13.4
    Couldn`t find out what the problem was. Tool nose radius is 0.4mm.
    Where does it get that 0.234 value? And in six`th line why does it go in z-2. as programmed. Could anyone help me here? Am I missing something at the previous settings? Tool measurements etc.
    Thanks anticipated!
    Feb 2008
    586
    First, I would have used G42 on MY lathe, a Hardinge CHNCII+.
    Second, have some movement in Z when turning on TNRC; you have Z3. on the prior line, and Z3. on the lie of TNRC
    It just seems that the control is trying to comp on the wrong side of the angled lines.
    Nov 2005
    219
    turn cutter comp on and feed to the start point.
    G0X---Z--- (RAPID TO .100 OF STARTING POSITION)
    G42GO1X---Z----(START POSITION FOR RADIUS)
    G01X---Z---R--- (CUTTER COMP ON)
    G01X---Z--- (MUST HAVE LINEAR FEED AFTER TO TURN CC OFF)
    G40 (TURN CUTTER COMP OFF)
    Mar 2003
    2932
    Sounds to me like it's compensating correctly (see attached .jpg file) for what you've programmed.
    Try this one:
    T0707
    G50S1500
    G96S180M3
    G0X43.Z3.
    G1G41X43.Z.2F.1M8
    G1X42.Z-.3
    G1Z-2.
    G1X27.6
    G1X27.Z-2.3
    G1Z-13.
    G1X26.1
    G0G40Z3.0
    Nov 2004
    110
    Nice graph dcoupar.
    What software did you use?
    Mar 2003
    2932
    QuickCAD... no longer made, but I still love it.
    I used to have similar problems on most of my programs with compensation. Then one day, an older machinist told me good way to ensure the compensation goes right. If turning external, begin at least 2* radius of the tool tip +0.2mm smaller (X-axis) than the first geometrical point is. If turning internal, do the same, but begin with bigger diameter. Since being told that, the compensation has been working just as it should be in all of my programs.
    Like this in your case:
    T0707
    G50 S1500
    G96 S180 M3
    G0 X43.6Z3.
    G1 G41 Z0. F.1 M8
    G1 X42.6
    G1 X42.Z-.3
    G1 Z-2.
    G1 X27.6
    G1 X27. Z-2.3
    G1 Z-13.
  1. G42 Tool nose radius.
    By al-108 in forum Okuma
    Last Post: 03-02-2008, 08:39 AM
  2. 6T - tool nose compensation
    By Bluey in forum Fanuc
    Last Post: 10-11-2007, 01:51 AM
  3. Replies: 2
    Last Post: 09-29-2007, 09:57 AM
  4. Fanuc 5T Tool Nose Compensation
    By John3 in forum Fanuc
    Last Post: 07-16-2007, 04:58 AM
  5. tool nose comp.?
    By pp-TG in forum MetalWork Discussion
    Last Post: 09-19-2006, 09:36 PM
