I have a 4x8 table with horizontal slats for the sheet to set on. How can you fix the table/slats so that you dont have sway/movement during cutting?
Any suggestions/ideas are appreciated. Thanks
You do that by cutting a slat support bracket that runs down the center of the table and you offset it one tooth so that when the slats are inserted they are bowed out a little putting tension on the slats prevents them from moving. Use one of your existing slat support brackets as a template.
