I have read that going around a corner or a curve can be a problem for some height controllers. Apparently what happens is when the CNC software uses something like continuous contouring to slow down around corners or in curves, as the torch slows down, the kerf gets wider, causing a higher resistance across the arc, which causes the height controller to think that the material has fallen away, so it drops the torch head down. One possible solution that is apparently used is to lock the height of the torch around curves or during speed changes, or I suppose if the torch height controller knew it was slowing down, it could basically expect a resistance change and not react to it in the same way that it might normally. Obviously either of the above solutions would require communication between the CNC controller and the height controller.
I've also read that the same thing (torch diving) can happen when crossing a kerf, though to be honest I can't remember if I've ever had to cross a kerf. Seems like the only time I ever get close to crossing a kerf is when the torch is coming back to the startpoint of the cut, and as soon as the torch hits the kerf, its about to turn off and the piece is going to drop, so I don't know if that's actually anything which would affect me, but I could see how the issue of going around corners might.
Does Torchmate's new AVHC take the above situation(s) into account, and if so, how does it handle them?
Thanks!
