603,960 active members*
2,462 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Torus pro stepper setup question
Results 1 to 7 of 7
    May 2009
    327
    My y and z axis are off. What are your values for step per?
    Almost ready to make some chips! Enclosure should be done tomorrow!
    -Keith
    Feb 2006
    7063
    Quote Originally Posted by keithmcelhinney View Post
    -Keith
    Mine was 10160 steps/inch. The screws are 5mm lead, and the steppers should be 10X microstepping.
    Regards,
    Ray L.
    May 2009
    327
    OK set it to 10160 and it is still way off. How do you check the steppers themselves?
    -Keith
    Feb 2006
    7063
    Keith,
    How are the switches set on your stepper drivers?
    When you say "way off" - how far? 2X? 10X? If you move 1" on Mach3, how far does it really move?
    Regards,
    Ray L.
    Jun 2004
    6618
    On my Torus, the Y axis was about 50% off. I think it was a switch setting, but never messed with that.
    I just used a dial gauge and got it set right to that.
    Both X and Z were perfect though. That is why I think it was a switch setting.
    Lee
    Feb 2006
    7063
    Here's the manual for the stepper driver:
    http://leadshine.com/UploadFile/Down/MA860m.pdf
    Are you sure you've got your units set correctly? Is motion perhaps off by a factor of 25.4?
    Regards,
    Ray L.
    Quote Originally Posted by SCzEngrgGroup View Post
    Regards,
    Ray L.
    I was thinking the same thing. Check that you got the units in Mach 3 in Inches, not mm's
    Nate
    Fine Line Automation
    Home - Fine Line Automation
    www.finelineautomation.com
  1. Torus Pro vs Torus vs Pulsar vs PM45-CNC
    By Titaniumboy in forum Novakon
    Last Post: 01-28-2014, 06:47 PM
  2. Torus Pro spindle question
    By uawgmsmco in forum Novakon
    Last Post: 11-17-2013, 06:29 PM
  3. Stepper based Mill Setup feedback question
    By Tkamsker in forum LinuxCNC (formerly EMC2)
    Last Post: 10-08-2012, 09:18 AM
  4. DC vs Stepper Setup question?
    By NVTS in forum DIY CNC Router Table Machines
    Last Post: 08-25-2010, 03:40 PM
  5. dual stepper setup question .
    By tony978 in forum Open Source CNC Machine Designs
    Last Post: 08-23-2010, 04:03 AM
