587,801 active members*
3,466 visitors online*
    Oct 2006
    100
    touch probe/Z0 setting block advice
    Hi, I want to make a probe or touch block to set the tool offsets in mach 3 for my cnc router. From what I can understand there are 2 different types that I have seen??
    Firstly the spring loaded sensor type which if I assume you attach to the machine bed and it sets the tool offsets relative to tool number 1/master tool?
    Second type I have seen is just a simple contact block/plate or 'puck' of a certain thickness which I am thinking is good for setting each tool individually without having to bring the tool down on top of the work.
    It has a kress spindle on the machine so the tools do not have seperate fixed holders just a removable collet clamp. Would the 1st probe type then be no good for what I want?
    any advice much appreciated
    Jan 2009
    28
    What is the make/model of that spring loaded unit you show?
    Did you ever get any further info to your question?
    Regards,
    Frank
  1. Touch Probe
    By Babba in forum Syil Products
    Last Post: 03-11-2022, 04:36 PM
  2. k2CNC 3D Touch Probe
    By Mike Stevenson in forum K2CNC
    Last Post: 02-14-2008, 07:44 PM
  3. Touch probe to ir receiver??
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 04-28-2007, 02:43 AM
  4. Touch probe for sale
    By cut more in forum Digitizing and Laser Digitizing
    Last Post: 03-08-2007, 12:50 PM
